Froggy Dolly
Dolly-Nut
Re: Froggy Dolly
#31 Post by Dolly-Nut »
dololo wrote:
other question , does anybody know what should be the fuel consumption for a 1850 auto ?
Laurent
35~mpg, depending on your journey lengths.
Re: Froggy Dolly
#32 Post by Carledo »
Original fuse rating is 35 amp blow rate with a 17 amp continuous load so your 10 amp jobs are never going to stand it!
dololo
Re: Froggy Dolly
#33 Post by dololo »
So today was the first time i was able to fix an electrical issue :D
Champagne !
dololo
Re: Froggy Dolly
#34 Post by dololo »
Good evening ,
my dolly is back on the road since last winter...with no heat in the car :(
I found a small leak of coolant between the admission ramp and the water pump , so i changed the inlet seal and the o ring seals between the pump and the head .
Now the heating is ok , but i still find a small leaks under the head
Any idea ?
Have a nice week end
Laurent
Dolly-Nut
Re: Froggy Dolly
#35 Post by Dolly-Nut »
From a slot in the block below the water pump cover?
dololo
Re: Froggy Dolly
#36 Post by dololo »
Hi ,
i met some of your members last week at stoneleigh and registered the TDC
i swapped my auto gearbox this winter ( noise in the torque converter ), for a 1850 OD one
i already have a good OD gearbox checked , but still need all the parts set to cover the gearbox
-cover 820500
-console unit XKC 1731
-vynile "gauntlet" on the lever
if anybody can sale these specific parts (sprint parts doesn't fit for 1850 gearbox) to france , please PM
PS for DAN : i already checked this zone , but saw nothing :(
Edin Dundee
Re: Froggy Dolly
#37 Post by Edin Dundee »
oops - wrong year!
Re: Froggy Dolly
#38 Post by Jon Tilson »
You may also need to change the axle ratio if you live in a hilly area.
You need a 3.63 and the auto is 3.27.
I will look for the parts you need. Is it an early or late gearbox. Is reverse next to 1st or 3rd?
dololo
Re: Froggy Dolly
#39 Post by dololo »
thanks for your help :wink:
it is a single rail gearbox , reverse is close to 3rd , on the right
Re: Froggy Dolly
#40 Post by Jon Tilson »
I'm sure I have the tray with its integral gaiter. There is also a rubber boot that is attached to the tunnel.
Do you have the tunnel? It won't be easy to find one in France. I dont think I have one for the single rail box....only the early 3 rail.
You may have to modify the auto one?
Re: Froggy Dolly
#41 Post by MIG Wielder »
I found this in my box of bits from years ago. I've measured it up and annotated some dimensions. I have also compared it with the one fixed in SWK which now has a single rail 1850 gearbox, but originally had that funny experimental CVT transmission installed. Something I realised was that the one installed slopes down at an angle of 30 degrees because the rear face is much shorter top to bottom. If this one in the photo was fitted the coin tray part would be close to horizontal.
So is this an 1850 single rail part ? If so and if Jonners can't find one it would be spare.
dololo
Re: Froggy Dolly
#42 Post by dololo »
Hello
here are samples of the part list
it doesn't make difference between "early or late 1850" in 1976
was single rail gearbox already in production this year ?
gearbox cover.jpg (128.54 KiB) Viewed 4357 times
Edin Dundee
Re: Froggy Dolly
#43 Post by Edin Dundee »
Yes, the single rail came in in late 1975 I think.
Re: Froggy Dolly
#44 Post by Jon Tilson »
Tony has posted a lovely picture of an early 3 rail tray....
The single rail is much shallower at the back edge....
This I think is how it works....you can use a single rail tunnel on a 3 raiil car but a 3 rail tunnel will probably foul the gearchange remote.
So you need a single rail tunnel to cover all the bases...
Mine (spare) is a 3 rail sadly....
Re: Froggy Dolly
#45 Post by MIG Wielder »
Thanks for that Jon ! Your knowledge is encyclopedic. So for what Laurent wants could he carefully cut this down to be the shorter single rail coin-tray if we supplied dimensions ? Or is it not that simple ? This one came from MPD my very early Stromberg powered 1850 from 1973 I remember now.
