Sprint engine number.
tom16v
#1 Post by tom16v »
Hi All!
I've been trying to find the engine number on my 2 Sprints ready to apply for heritage certificates and I can't find either of them where the book says they should be on the shelf of the block.
Please can someone enlighten me? :D
Thanks in advance.
Tom.
1979 Carmine Dolomite Sprint
2005 Mystic blue BMW M3
2004 Mystic Blue 330d
2001 Peugeot 206 Hdi180
Re: Sprint engine number.
#2 Post by Jon Tilson »
I have yet to see an engine number on a slant 4 block that I have owned....
The only one I remember was on a gold seal lump that's now in Ricky's LCO.
Don't worry is what I'm trying to say...
You should get the heritage bumpf from the chassis plate.
tom16v
#3 Post by tom16v »
OK. Thanks Jonners. I will just send them the Chassis numbers then.
Thanks for your reply.
Tom.
#4 Post by xvivalve »
You could look on the V5c...
#5 Post by DoloWIGHTY »
This might help?
DoloWIGHTY wrote:Engine number is not where it's officially suppose to be :wink: This might help you find it.
Engine number is here:
Just below the carb springs bracket:
Very faint, probably need to a wire brush, mirror and a inspection lamp - and a third hand.
dursley92
#6 Post by dursley92 »
Here is the one on my spare engine
Russ Cooper
Dursley
UK
Well.......
#7 Post by sprint95m »
I have only once looked for a slant four engine number.....
it was on the block very close to the cylinder head, just visible when peering into the gap of the inlet manifold (early Sprint),
so quite a different to Russ's photo. In other words, keep looking :) .
tom16v
#8 Post by tom16v »
Hi All.
Thanks again for the replies.
I havent looked lower down where the pictures are showing it so will look there later.
I am not sure of the originality of my cars, so was hoping to check the numbers against the V5c Alun.
Cheers folks.
Tom.
straylight
#9 Post by straylight »
Russ looks like he has used the chalk method to show the numbers up. Good idea. My engine numbers (all 3 engines) are in the same spot as Russ's.
stu
#10 Post by Mad Mart »
I've seen them stamped in two positions...
