Having aquired a secondhand weber manifold for the Sprint, I now need to work out what size threads are used for the studs,thermostat housing, water pipe & temp sender.
Anyone got an idea?
Weber manifold threads
1981 1500 HL man/od
2007 MX5 Sport
2010 Citroen C1
1993 Gas Gas GT32
1981 1500 HL man/od
2007 MX5 Sport
2010 Citroen C1
1993 Gas Gas GT32
Re: Weber manifold threads
Studs: M8 (13mm Nut).
Thermo housing is usually bolts but 5/16 UNC.
Temp Sender: 5/8 UNF? - Water pipe the same?
