I am lucky enough to have a Powr Lok LSD fitted to my car.
I want to change the oil, can anyone recommend one.
Another forum is recommending Morris XEP 80w/90 is this any good?
Powr Lok LSD - Oil Change
Re: Powr Lok LSD - Oil Change
You need an oil for use in plate type LSD's. miller do the correct oil. I will check later what number it is, as its what I use in mine
Cheers for that.
I read on the Sprintparts website the original spec was Castrol Hypoy LS it seems to be available still but whether it is the same spec as back in the 70's I am not sure.
There are a few suitable oils. If they have the LS or LSD in their type name it is ok. Then it's suitable.
Thanks guys, just ordered some Millers from Opieoils.co.uk currently got an offer on for 25% off all oils, offer code MAYHEM. Not sure how long the offer is valid for.
