Wing removal and front end overhaul
ToledoZombie
Re: Wing removal tips?
#16 Post by ToledoZombie »
That did look pretty nasty
Here's mine as of 5 mins ago
Reason: Image re-sized
ToledoZombie
#17 Post by ToledoZombie »
Here's more
ToledoZombie
#18 Post by ToledoZombie »
Got this off and will strip prime and offer for sale , thought it does have small bits of corrosion at the ends
Re: Wing removal and front end overhaul (maybe move to resto
#19 Post by xvivalve »
That nearside eyebrow is fantastic!
The top panel should sort someone out of a hole; congratulations on your patience!
ToledoZombie
#20 Post by ToledoZombie »
Apologies on the size of my photo's
I uploaded straight from my phone. I guess i need to put the setting a bit lower.
I will put the panel in the for sale section to try and get some interest, then maybe put on the bay so to try and get as much as possible for new panels.
#21 Post by Carledo »
YUP! That old inner panel looks pretty much like mine did, except you have slightly more in the way of eyebrows, believe it or not!
Hi again....
#22 Post by sprint95m »
Andy, I have moved the topic.
As for the photos, maybe Alan will resize these for you and put them onto a suitable hosting site.
#23 Post by DoloWIGHTY »
I have resized them though I have a feeling one has gone missing during the editing? :oops:
#24 Post by Carledo »
Some inspiration for you! Mine was as bad as yours and look at it now!
At Prodrive
casual snap at a mate's yard
Club sills fitted and club GRP wings and front panel, the holes at the original numberplate area were my own idea to get more air into the Saab rad I have fitted!
ToledoZombie
#25 Post by ToledoZombie »
Looking good Steve, I look forward to getting mine looking good again
ToledoZombie
#26 Post by ToledoZombie »
I have made a slow start today on Chuckie, many thanks has to goto Alun for his great service supplying the panels.
I've started with the nearside cill. Looks like I will be renewing parts of the inner cill while I'm at it
#27 Post by DoloWIGHTY »
As you say, that reinforcer only looks a few weeks old - good result :thumbsup:.
ToledoZombie
#28 Post by ToledoZombie »
I was very surprised after 42 years hidden away inside the cill
ToledoZombie
#29 Post by ToledoZombie »
A little more progress today, I have put a step in the rear section and trimmed the edges so the new section should sit snugly in place.
I've chopped some inner section out ready to let in some new.
Also I think I may cut out and weld in a small piece that sits under the lower wing section as you'll see it warrants renewal if I'm to do a job that's going to last.
I was surprised at how good it was inside considering it hadn't been waxoyled, however I'm going to need to do this once its all welded. Any suggestions on the best way to do this?
Should I coat the edges to be welded in any sort of coating, such as zinc spray?
Nathan Mwk 627G
#30 Post by Nathan Mwk 627G »
When I did the same work on my 1300fw earlier this year I used weld through primer on all the edges that were to be welded, worked great and you have the satisfaction that there is something there protecting the edges, I used a brush on type I bought from Stoneleigh, id never used it before but I was impressed with it.
When you have completed the rebuild the easiest way of getting wax oil in the sills was to drill some holes on the "upper" sill, around the area that is usually covered with the tread plate, I blasted about 1.5L each side using a compressor.....once your done refit the tread plates and nobody is non the wiser that its been done like that!
Nathan
