Neil907
Re: My new road And occasional track day car
#331 Post by Neil907 »
Good progress, looks like allot of work but will be worth it all in the end.
DF
#332 Post by DF »
Neil907 wrote:Good progress, looks like allot of work but will be worth it all in the end.
Cheers Neil.
One of the reasons ive done this is as I want to fit air conditioning .
Nothing worse on a track day than sweating your T**S off
#333 Post by soe8m »
DF wrote: One of the reasons ive done this is as I want to fit air conditioning .
You are aware off that an airco does eat 10hp when full on?????? :lol:
#334 Post by Mad Mart »
So you're only going to have 990 Daz.
DF
#335 Post by DF »
Didn't think of that ,
Dam is it worth it ??? :amigo:
#336 Post by Toledo Man »
Don't forget about the extra weight. The compressor alone must a couple of kilos.
DF
#337 Post by DF »
Toledo Man wrote:Don't forget about the extra weight. The compressor alone must a couple of kilos.
It may be a no go as the dry sump pump is in the way !!!
And with this new type on inlet plenum I cannot move the pump up high enough
Need to do some head scratching
I wonder if I can run it off the prop shaft suitably geared ??? Mmm
Jod Clark
#338 Post by Jod Clark »
I reckon a man of your ability could work out a way of running the aircon compressor from a butchered electro-hydraulic power steering pump motor such as that found in the Saxo / 106 or Astra / Zafira etc....?
1300_2door
#339 Post by 1300_2door »
I assume you mean gear it down, not up ? :wink:
I've seen a alternator running off a propshaft, It was on a Triumph 2000 mk1 race car IIRC
wiggybum
#340 Post by wiggybum »
Ford Transit 2.5di run a vacuum pump off the rear of the alternator via a splined output shaft.
Could you both things off one pulley that way?
1981 1500 HL man/od
2007 MX5 Sport
2010 Citroen C1
1993 Gas Gas GT32
DF
#341 Post by DF »
Jod Clark wrote:I reckon a man of your ability could work out a way of running the aircon compressor from a butchered electro-hydraulic power steering pump motor such as that found in the Saxo / 106 or Astra / Zafira etc....?
yes but would need a 160 amp alternator to run just that one thing...
DF
#342 Post by DF »
:D Well down
DF
#343 Post by DF »
wiggybum wrote:Ford Transit 2.5di run a vacuum pump off the rear of the alternator via a splined output shaft.
Good idea but I don't think I have the room behind the alt,
#344 Post by soe8m »
DF wrote: yes but would need a 160 amp alternator to run just that one thing...
1,6 amp:
DF
#345 Post by DF »
1,6 amp:
a bag of ice cubes behind the fan
May work for 1 lap :D
