MSO 662P
Dolomite1296
Re: MSO 662P
#196 Post by Dolomite1296 »
Lovely car and total credit to you.
Re. tyres: wouldn't 185/50s give you a little more clearance? 185/55s tend to be rather square shouldered.
Tony Burd
Re: MSO 662P
#197 Post by Tony Burd »
Cleaned up the water pump cover
Before....
After.....
Then fitted the pump to the block
Impellor next
Finally the housing with appropriate thickness gaskets.
Tony Burd
Re: MSO 662P
#198 Post by Tony Burd »
Thanks for your comments.
I need a new set of tyres, not had a proper look yet but I don't think you can get 185/50/15s which I find hard to believe, but these days a 15" wheel is pretty small for modern cars so there is not much choice.
The width would still be the same just a lower profile which would give me more clearance if I kept the ride height the same.
Dolomite1296
Re: MSO 662P
#199 Post by Dolomite1296 »
You're quite right, 185/50s are not a common tyre, but remain available from Camskill and other tyre wholesalers.
Tony Burd
Re: MSO 662P
#200 Post by Tony Burd »
Just had a look on their website, couldn't see any listed, is it best to ring them?
lazeruspete
Re: MSO 662P
#201 Post by lazeruspete »
I am a fan of the white engine block!
any reason why? I think it will come in handy for spotting any oil/fluid leaks should they arise :-)
viewtopic.php?f=19&t=23031
Proud TDC Member!
Tony Burd
Re: MSO 662P
#202 Post by Tony Burd »
Just fancied something different, it's already looking a bit grubby just sitting in the garage but does clean up ok, yeah will be good to spot leaks.
Dolomite1296
Re: MSO 662P
#203 Post by Dolomite1296 »
I usually find it easier to speak to Camskill rather than using their website. Frustatingly I found a source of these about a month ago but can't recall who it was offhand. I'll have a crash around on Google and get back to you. It may have been from one of the Smart forums.
Tony Burd
Re: MSO 662P
#204 Post by Tony Burd »
Great thanks for that. Do you know your stuff about tyres? If so can you recommend a really good road tyre, the car will mainly be used in th dry and probably won't do a lot of miles, so I am not bothered about how long they last, would rather have something softish & sticky
SprintMWU773V
TDC Staffs Area Organiser
Re: MSO 662P
#205 Post by SprintMWU773V »
Tony Burd wrote:Great thanks for that. Do you know your stuff about tyres? If so can you recommend a really good road tyre, the car will mainly be used in th dry and probably won't do a lot of miles, so I am not bothered about how long they last, would rather have something softish & sticky
Any Yokohama will be sticky! Also look at some things like Vredestein. Not sure what sizes they come in but my Mazda has the Sportrac 3's in a 15" and they are a nice tyre. Never seen a 185 50 in a 15" but you can definately get a 185 55 though this may be too tall if you're going 15". I suspect choice will be limited to whatever is available. Personally having tested some cheap Chinese tyres under extreme wet and dry braking I would buy something of reasonable quality. In the test I ran I would have ploughed into the back of the traffic queue at 22mph instead of stopping in time and avoiding an accident.
Tony Burd
Re: MSO 662P
#206 Post by Tony Burd »
Definitely won't be going cheap on tyres, Yokos sound good, been looking this morning & can't find any lower profile than 55 on 185 wide, more options on 195s but they will definitely rub the arches so not an option.
Re: MSO 662P
#207 Post by Carledo »
Tony Burd wrote:Definitely won't be going cheap on tyres, Yokos sound good, been looking this morning & can't find any lower profile than 55 on 185 wide, more options on 195s but they will definitely rub the arches so not an option.
I'm running the Carledo with similarly modded arches and a choice of MGF or minilite replica 15s (though I think both sets are only 6" wide)
The F rims have 195/50/15 Toyo R1s which cost me £50 each a couple of months ago through a trade mate. These are BEAUTIFULLY sticky! The minilites are wearing Yokos, also at 195/50, whilst these are also pretty sticky, I seem to have worn them out in a little over 3000 miles (they are now my racing slicks!)
With polybushing, Gaz adjustables and the modded arches, (almost exactly what you've done) Ive now got the ride height roughly level and the tyres don't rub.
When first built, I had flanged standard arches, knackered original bushing, newish stock shox and 205/50/15s on the F rims. Even with the (accidental) tail high stance the car had then, the tyres rubbed the arches a bit when cornering agressively, but not any more and the Gaz have let me drop the rear ride height by almost 2"
I'm pretty sure the minilites have a slightly bigger offset than the F rims but, like you I'm going to get 3-5mm milled off them to help with potential problems.
Flyfisherman
Re: MSO 662P
#208 Post by Flyfisherman »
Tony Burd wrote:Thanks for your comments.
Have a look at the attached short cut - my be helpful to you
http://www.tyrereviews.co.uk/Tyre-Size/15-Inch-Tyres/
Regards
Paul
Jod Clark
Re: MSO 662P
#209 Post by Jod Clark »
Carledo wrote:...........195/50/15 Toyo R1s...........
:thumbsup:
photo 3a_001a.jpg (184.27 KiB) Viewed 2020 times
Tony Burd
Re: MSO 662P
#210 Post by Tony Burd »
Thanks for the replies, I had the old tyres removed today as I am going to refurbish the rims, the guy at the tyre place said Yokos or Toyos, will see what is available once the wheels are finished.
Gave me a chance to measure them, they are 6.5" wide from the outer to inner rim:
I could also measure the distance from the inner rim to the inside of the wheel, it's about 105mm, Steve do you know what you have on your wheels?
I have to be careful how much the offset is increased, looks like a maximum of 4mm, otherwise I will have to shorted the wheel nuts.
So I think I will have to stick with 185/55/15s
