1850HL not really a restoration
Karlos
#1 Post by Karlos »
Here is my 1850 HL. I have had it about 10 years. It had 8 months MOT when I bought it, but I soon realised it was a rusty heap and should never have had an MOT in the previous 5 years. After the MOT ran out I got really hacked off with it, I did loads of work but each job seemed to lead to another:
Welded up the sills,
Welded up the rear wheel arches,
Reconditioned the water pump,
Fitted a new head gasket,
Replaced the gearbox as it would jump out of first gear,
Fitted new steering rack mount bushes,
Fitted new upper and lower steering column UJ's.
Replaced all the shocks with new ones.
Fitted electronic ignition.
Replaced the rotting exhaust with a stainless one.
I shoved it in the garage and bought myself an MX5. Then this year I decided I needed the garage space to sort out the MX, so I got it out and did the following for the MOT between Feb and July of this year:
Replaced all the brake pipes with new copper brake pipes.
Replaced the Master cylinder and front caliper brake seals.
Welded up a hole I'd missed in the rear wheel arch.
Cleaned the carbs from gummy old petrol and crud.
Rebuilt both front upper suspension ball joints.
Replaced both track-rod end ball joints.
It is now on the road and just beginning to start giving a bit back in return for the work I have done.
Karlos
Re: 1850HL not really a restoration
#2 Post by Karlos »
And now for the todo list, or is it a wish list, honest truth it's a "what is actually wrong with it list"...
Replace the sills, reinforce the jacking points and inner sills and whatever I find behind the outer sills that is rottern
Replace the leaking windscreen seal
Replace the torn headlining and sunroof
Re-spray the whole car
Noisy diff -needs something to be done not sure what
Exhaust is blowing from a couple of the joints in the centre section
Re-varnish the door cappings
Boot lid flaps up and down - it doesn't close tight
All the doors are hung badly - clearances are all over the place
Carb mounts are perished / cracked
Rear end seems a bit sloppy, sometimes it feels like it is steering itself like a fork-lift truck.
#3 Post by Toledo Man »
Glad you've started a thread. Your rear end steering is either seriously tired bushes or one of the axle mounts for the tie bars has broken off. I had this happen on my Dolomite 1300. I tried welding it but it didn't last so I ended up replacing the rear axle.
Keep us updated with your progress and ask for any advice you may need.
Yes.....
#4 Post by sprint95m »
Thanks for starting this thread, it is one I will follow with interest.
Keeping a car on the road whilst improving it is a challenge, very different to a restoration and,
to me at least, of more interest.
Please keep us informed.
#5 Post by Toledo Man »
I agree with Ian's comments on rolling restorations. It does cost more in the long run but the car can be enjoyed and the driving experience gets better as the car is improved. Mine is getting better since coming back from the MoT.
Karlos
#6 Post by Karlos »
I got a replacement steering rack. I have undone the trackrod ends and the steering column and undone the clamps too. I was expecting the trackrod ends on the replacement rack to be a pain but they came undone without any problems.
It looks like I'll need to undo the front engine mounts and jack up the engine to get clearance. I had a go at just jacking up the engine but still could not get the u-bolts out. After a quick read of my "Autodata Dolomite Car Repair Manual", it suggests the rack can be removed by jacking the engine up a bit, but like everything in that book it is talking rubbish. I'll have another look tomorrow.
Yes....
#7 Post by sprint95m »
You do indeed need to undo the engine mounts to be able to lift the engine sufficiently high.
The good news is that you don't have to undo anything else, the hoses, cables and so on will be okay.
As with most jobs in this area it is sensible to remove the battery first.
It is safe to use a trolley jack under the sump (with a piece of wood to spread the load).
:) You were lucky with the track rod ends, it isn't always the case.
#8 Post by xvivalve »
You only need undo the driver's side mount as its only that U bolt that interferes with the engine. If you undo both mounts, the engine will not tend to rotate as you lift it and that can put strain the top radiator hose.
Karlos
#9 Post by Karlos »
All done. As you both said I needed to undo the o/s-drivers side mount then I got the engine high enough to remove the U-bolts. Got it all back together by lunch time today and borrowed my mates tracking bar to get the wheels 'close' to being aligned.
According to my Autodata manual (pinch of salt required) the tracking is correct when the distance between the rims at wheel center hieght is 1 -1.5mm less on the edge in front of the hub compared to the distance between the rims behind the hub. what this means in term of toe in angle I don't know - or if it is an accurate bit of data either.
Can anyone tell me what the correct toe in angle is?
#10 Post by Toledo Man »
This is what my Haynes says:
The front wheels are correctly aligned when they are turning in at the front zero to 1/16 in (zero to 1.588 mm).
Karlos
#11 Post by Karlos »
Mmm, doesn't really make it any clearer. Does the Haynes book say where the measurement is taken?
#12 Post by Jon Tilson »
With the track bar just get it parallel then toe in to the first graduation or half a degree IIRC
Works for me...
#13 Post by Toledo Man »
More from Haynes...
It is important that this measurement is taken on a centre line drawn horizontally and parallel to the ground through the centre line of the hub. The exact point should be in the centre of the sidewall of the tyre and not on the wheel rim which could be distorted and so give inaccurate readings.
Karlos
#14 Post by Karlos »
Fitted a solid state indicator relay. Nice steady flashing from the indicators now, instead of 1 flash in 5 seconds.
Also varnished the door cappings.
#15 Post by Toledo Man »
Any joy whith the front wheel alignment? There should be a bit of toe-in (as per the previously mentioned figures) which means that the distance between the front of the wheels should be less than at the back. My basic diagram below illustrates toe-in. The difference is hardly noticable to the naked eye in reality but the diagram should give you the idea.
Front of front wheels
Rear of front wheels.
Hope this helps.
