Distributor rotor position
AlanH
#1 Post by AlanH »
This is a bit of a daft question but it has been bugging me.
I removed the distributor recently and noticed that the center shaft can be replaced in almost any position. I decided that, so long as the rotor was pointing to the cylinder 1, lead at TDC then it should not matter providing I got the other leads in the correct sequence.
I replaced the shaft the way that I think it came out so, looking down on the dizzy from the exhaust side the No1 lead went on at the bottom right hand corner. The rotor pointing this way at TDC.
The engine has started running a bit rough recently so I'm wondering if the positioning makes any difference. My logic tells me not but I wonder if there is a 'correct' position.
Re: Distributor rotor position
#2 Post by Jon Tilson »
What sort of dolimite are we talking here? Its a bit different between the ohc cars and the ohv ones.
On an ohv car thr driving dog is offset so its pretty hard to get it back in wrong.
On a slant car the toothed cog can go in as many ways as it has teeth on the drive cog. The trouble is the teeth are on a skew gear so the rotor arm rotates quite
a lot as the cog engages. Its about 30 degrees IIRC. So the position you want it in is with the tooth that goes with the adjusting slot about in the middle when you do the bolts
back up. Easier said than done. So put the crank at 11 btdc or whatever and then put the dizzie back in so that the points are just opening and the rotor arm is pointing at no1
in the cap. On a Sprint its easy to get this wrong. Look carefully at the leads and which one goes with which rotor position. If you havent changed the leads in the cap
it should go back the same and run ok.
You will need to set the timing up with a strobe to get best running. If the position is up against one end of the slot you can move it round one tooth so it can be adjusted both ways.
AlanH
#3 Post by AlanH »
It's an 1850 AC Delco
Dolly-Nut
#4 Post by Dolly-Nut »
Sounds like you haven't timed it but yes you did it right. Bare in mind that with a slant it's easy to make the mistake of 180deg out (which you haven't made if it's running).
#5 Post by Toledo Man »
With No. 1 cylinder in the firing position the rotor arm should be pointing at one of the inlet manifold bolts (I think it is the 2nd one from the left looking from the driver's side) when you take the dizzy cap off. The points are a right royal PITA to get to. Fitting a Sprint dizzy and the Britpart electronic ignition kit was one of my better moves.
Hope this helps.
#6 Post by MIG Wielder »
Have a read of this ....
https://www.dollywiki.co.uk/wiki/1850_D ... ts_setting.
...... and this perhaps. It may help.
https://www.dollywiki.co.uk/wiki/Dolomi ... adjustment
Good luck with sorting it.
#7 Post by Jon Tilson »
If you get an 1850 180 degrees out you can just switch the leads around.
The dizzie can go in any one of 4 positions. Just make that position point to no1 and then set the
others according to the firing order, 1-3-4-2
Dave's wiki guide on setting 1850 points and general dizzie stuff is a good read and nice pics.
You may want to go down the electronic ignition route at some stage.
