Triumph 1500 FWD
K100ASG
Triumph 1500 FWD
#1 Post by K100ASG »
Hi everyone hope your all well, do the dolomite alloy wheels fit the Triumph 1500 FWD ???
Dolly-Nut
Re: Triumph 1500 FWD
#2 Post by Dolly-Nut »
Yes it's the same PCD.
#3 Post by xvivalve »
They may be the same PCD, but they won't fit the front hubs on the FWDs, I believe...?
Well.......
#4 Post by sprint95m »
On a Club Triumph Round Britain Reliability Run 4 or 6 years ago I saw a 1300 with Sprint alloys fitted.
I can post a photo if anyone is interested......
Triumph1300
#5 Post by Triumph1300 »
They will bolt on, however, the offset is far to big, and the suspension geometry at the front doesn't work too well.
You will almost certainly foul the rear arches
Yogi of Club Triumph has/had them on his 1300, but with suspension mods I believe.
Rover 114 alloys have the correct PCD, and almost correct inset. You may need a 3 mm spacer on the front to clear the top ball joint.
Look for pictures of my 1300 KAC to see what they look like
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
#6 Post by Jon Tilson »
The o-p said a 1500 fwd not a 1300.....
Alun may still be right but the 1500 fwd is much more dolomite like than a 1300.
Triumph1300
#7 Post by Triumph1300 »
They're the same wheels, hence my comments
BWJ
1300_2door
#8 Post by 1300_2door »
Triumph1300 wrote:They're the same wheels, hence my comments
Yes, the front track on the 1300Fwd and 1500Fwd is the same, which is 1.5" wider than Dolomite's and Toledo's (irrespective of wheel offset). But the rear track of the 1500Fwd is 2.0" narrower than the 1300Fwd, so any clearance problems would be more on the front than the back.
As for handling issues, "I" believe this just down to the greater scrub radius highlighting existing suspension/steering problems rather than any designed geometry differences, the Fwd hub only adds 2-3mm to the track of the front suspension, the rest of the extra track is different fulcrum brackets.
(lighting blue touch-paper)
Gordon
Triumph1300
#9 Post by Triumph1300 »
Hi Gordon,
. Agree with you on the front, effectively, you are moving the centre of the tyre contact patch well outboard of the ball joint centre line.
. Didn't realise the rear track of the 1500 fwd was so narrow, especially as the rear drums appear to contain spacers!
. Mind you, you and I work on the technically superior 1300 FWD, with all round independent suspension.
. Pulls pin, throws grenade, runs away!
BWJ
As requested....
#10 Post by sprint95m »
Photographed at John O'Groats during the 2010 Club Triumph Round Britain Reliability Run.
