Agreed that a good go with a machine polisher and some cutting compound (not t-cut, too mild) may do the trick. At worst you will not make much of an improvement or will go through the paint to the primer. Then you will have lost some time and effort but not much else, and will still need a respray.
If you are keen on selling though, I would be advertising it as is. Many people want just such a car, and would be suspicious that a fresh respray may be hiding all sorts of nasties. At the moment it is totally honest, and all can see that.
Cost of respraying a Dolomite VS increase in value
Re: Cost of respraying a Dolomite VS increase in value
I'd say £2500 if you take all the trims off windows out, handles off etc.
cliftyhanger wrote:Agreed that a good go with a machine polisher and some cutting compound (not t-cut, too mild) may do the trick. At worst you will not make much of an improvement or will go through the paint to the primer. Then you will have lost some time and effort but not much else, and will still need a respray.
Good advice
Right, plan now is to spend a couple of hundred getting the paint polished and sealed by a professional detailer who did my Alfa.
Watch this space!
Watch this space!
I found this stuff worked a treat on the very faded (almost pink!) paint on my Spitfire:
It even impressed Ken
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
