So as I wanted a sprint, is it possible to fit the twin lamps from one to a Toledo? Are the two cars even the same size? I dont know what the two cars share etc. Im no novice to mechanics, which is obvious when you run land rovers as you kind of have to be but ive not seen the two cars side by side.
My first priority is suspension. I believe it has herald stuff on it hence why its pretty much touching the floor. Is there a coilover type kit available or a common lowering technique. I want it lower than standard but this is clearly too much.
Any other help/links to sites/pointers on what to do id be grateful.
This car hasnt been on the road for 17 years so it will need some recommissioning too so a place to get parts and recommendations on what parts to get will be gratefully welcomed.
Thanks in advance, and here she is:
