Hello does anyone have any data on the Sprint valve spring pressures? I have my old set and a set of the "Terrys" springs that appear on ebay now and then. I don't want to over pressure the rockers if I don't need to but could do with knowing what they should be as standard. Wouls ideally like to know the installed height pressure and open pressure (with stock cam for now)
Valve spring pressures? Sprint
