Hello there everyone!
Been getting a bit of trouble lately when I try to start my car, warning lights come on fine, but if I turn the key to start the car, nothing happens. However if I push the key inwards into the barrel more, the engine turns and she starts no trouble. I'm thinking I've got a dodgy connection somewhere but I've been reading about sheared bolts to stop thieves and all sorts, so was wondering where to start? Is it all contained (inaccessibly?) within the barrel?!
Thanks in advance!
Dodgy ignition barrel?
- HQentity
HQentity (Kyle)
Aye...
There is a bit of good news here, the ignition switch can be removed without the need to remove the actual steering lock barrel.
From experience I would try the switch first.
With the steering column shrouds removed, the ignition switch will be visible. Little grub screws hold it in place.
The wiring is more tricky to deal with since the s/column has a sleeve which prevents the switch's plug from passing
through
through
- HQentity
Re: Dodgy ignition barrel?
Thanks very much Ian, will have a good look and see what the problem is! Just good to grab some advice before I crack into it really.
Thanks!
Thanks!
HQentity (Kyle)
Re: Aye...
Are you sure? Both stalks can be changed without removing plugs, what is different about the switch?sprint95m wrote:The wiring is more tricky to deal with since the s/column has a sleeve which prevents the switch's plug from passing
Yeah.......
Thanks for pointing that out Julian,tinweevil wrote:Are you sure? Both stalks can be changed without removing plugs, what is different about the switch?sprint95m wrote:The wiring is more tricky to deal with since the s/column has a sleeve which prevents the switch's plug from passing
You can get the plugs through the sleeve, you just need to unbolt the top of the column to drop it down then push the sleeve down to the thinner lower column. The parcel shelf needs to be removed too. Or the column removed from the car.
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
It can be tested without putting it in the proper column sleeve first. I would try the new one to see if it fixes the problem.
Then you can dismantle the column and fit it in the sleeve/shroud at your leisure.
It can be done in situ with practice but I find it less grief taking the column out.
