Erratic rev counter And engine holding back
spriteley55
#1 Post by spriteley55 »
have changed numerous parts of the ignition system to try to eliminate these problems but had no joy - any suggestions welcome, thanks
Re: Erratic rev counter And engine holding back
#2 Post by Jon Tilson »
Year and model and location would be helpful.
spriteley55
#3 Post by spriteley55 »
Jon Tilson wrote:Year and model and location would be helpful.
1977 model sprint auto - I live in Hertfordshire
Howard81
#4 Post by Howard81 »
An identical problem with my Sprint turned out to be the electronic ignition module slightly lose. The screw in the kit was fractionally too long so didn't hold the module down properly.
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
#5 Post by Carledo »
I've often found an erratic (or non functioning) rev counter to be a pointer to a coil fault. Its also possible that the rev counter itself could be causing the problem, on a lot of Triumphs the engine won't run if the rev counter is disconnected (or duff) Obviously check all the connections into the rev counter before swapping it, especially the earth. But i'd try the coil first!
steve5
#6 Post by steve5 »
Just had a similar thing on mine which turned out to be a partially separated wire from the fuse box, (the pair of purple ones), it actually affected a few thing but the only easily noticeable one was the rev counter. I think I probably bent it when changing the steering UJ.
Aye...
#7 Post by sprint95m »
Carledo wrote:Its also possible that the rev counter itself could be causing the problem, on a lot of Triumphs the engine won't run if the rev counter is disconnected (or duff)
Only on the models with the rev counters connected to the positive terminal on the coil,
which for the Dolomite range applies only to the early 1850s (with the rubber connector blocks in the wiring loom).
