dos dolomite wheels fit 1300 fwd
anyone know if dolomite alloys fit a 1300 fwd or dose spitfire wheels fit im after a set of alloys to fit my 1300 fwd
Re: dos dolomite wheels fit 1300 fwd
PCD wise yes but they will have the wrong inset....
- Triumph1300
You can bolt Sprint alloys on, but without some re-engineering, you run the risk of front end grip issues, and bump steer. Dependent on the car, you may also run into rear arch fouling issues.
The Green/Blue 1300's seen in the last issue of Dolly Mixture are running Rover 100 series alloys, which have the correct offset for the 1300, with additional width.
The blue car on the lattice alloys runs 3mm spacers on the front for ball joint clearance insurance.
3/8th wheel nuts are available to suit these rims.
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
