Dash "Brake" Light
RJF_70
Dash "Brake" Light
#1 Post by RJF_70 »
On my 1500 auto, the dash Brake light seems to work a bit wierd, so looking for an explanation how it should work? It flickers when turning ignition but doesn't stay on at all in any gear or pressing brake pedal. So can anybody tell me how or when it should be on?
Cheers Rich..
1981 Dolomite 1500 Auto
Re: Dash "Brake" Light
#2 Post by Jon Tilson »
It depends. If you have a late car with a dual circuit master it should be off except when you have the handbrake on.
If its on when running its because the shuttle switch has activated due to a pressure imbalance between front and rear circuits.
This may require attention, or it may be because the shuttle switch was not reset after a brake overhaul. This is the mots common
scenario these days....
If you have a single master its only the handbrake that should make it come on. If it flickers when running its acting as an earth return so one of your dashboard earth points needs a clean up.
AlanH
#3 Post by AlanH »
Looking at the age of your car I suspect that it has dual circuit braking.
Try putting a spacer in the shuttle connector (on the bulkhead).
If it goes out that is your problem.
Are there any instructions anywhere on balancing this up ?
Flyfisherman
#4 Post by Flyfisherman »
Bias valve probably requires an overhaul / cleaning - see attached - viewtopic.php?f=19&t=22754&hilit=projec ... 90#p234448
pictures courtsey of Martin's project.
Paul
RJF_70
#5 Post by RJF_70 »
It's never on except when turning ignition! Never comes on with handbrake. I thought it may have been something to do with the auto box or something but judging by previous posts probably not. Think tomorrow I will try starting with handbrake off see if it lights up at all with ignition as a starting point!
Cheers Rich..
Washdog
#6 Post by Washdog »
I thought that the brake warning light on the flat dash models was only to indicate the loss of one side of the dual circuit system and didn't act additionally as a handbrake warning light as the HL models do.
Ian
Howard81
#7 Post by Howard81 »
Easiest way to check where the problem lies is to disconnect the wires at the bias valve.
The bias valve warning light was always intermittent on my car so I've disconnected it.
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
