Illuminated switch
sailor sam
Illuminated switch
#1 Post by sailor sam »
I have just recently bought a 1972 1500 FWD. I have just discovered a switch that was mounted in the parcel shelf between the steering column and the central heater deflector control that is above the gear stick. The switch is the type that is pulled in and out, with a bulb mounted within the knob itself. I only discovered it when I removed the parcel shelf to replace the clutch slave cylinder. I found the body of the switch hanging down behind the shelf and later found the knob in the glove box minus the bulb. What is it for?
gmsclassics
Re: Illuminated switch
#2 Post by gmsclassics »
Heated rear window, which after over 40 years may not be functioning, hence the disconnetcted switch?
#3 Post by Toledo Man »
Welcome to the forum. Don't forget to join the Club. The membership fee is worth every penny.
sailor sam
#4 Post by sailor sam »
Thanks for the information. I live in Sutton Coldfield, I am already a member of the TSSC which meets at the Boars Head Gt Barr. This club is great for my Spitfire Mk IV but not so good for my new 1500 FWD. Does the Triumph Dolomite Club have meetings close to Sutton Coldfield in the West midlands?
Triumph1300
#5 Post by Triumph1300 »
The Coventry branch meet at the Standard Triumph Club in Coventry, last Wednesday of the month, ie Tomorrow!
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
