I've canabalised an old thermostat to make an orifice plate to put a slight restriction into the system to make sure the water is forced through all of the head so as to reduce the chance of hot spots at the rear too...
......though with the hot feed to the heater coming from the back of the head that will probably cause coolant to be drawn all around the back any way....
I've not quite organised where the wires are going yet but they will be tidied and made less like a Rat's nest at some point!
