Dolomite 1500TC V6 swap and race build
Well, thought I'd start a resto-mod thread as I thought it would be a good way to track my progress.
But first, a littl back ground on my car. It's a 1500TC and had it for just over two years, I bought it from someone in rugby for the small sum of £380. It had a blown head gasket and a horrible mat black and grey paint job, which was half primer grey and the other half paint brushes matte black. It was kind of a restoration project just getting it road worthy and looking ok. Me and my dad spent a few months getting the engine apart to replace all the bearings and seals which wasn't too hard compared to the next 4 months doing all the body work and interior.
The body work sanding was done by hand, by me, so it took about two months of work to sand off the black paint and to etch the primer that was exposed. My dad had some gear that he used to spray his cars when he restored his cars so he put both the primer coat and the colour layer. the colour I wanted the car was signal red as I thought it was a deep red and looked quite nice but the colour I ended up with was a very bright red, with a black roof as I didn't want to fit a vynle roof cover. It was a nice little motor, ran smooth when off choke and was roomy, but since owning it it's been through 3 head gaskets, 3!!
So after a year, I got into a small accident and crushed the nose so I took it off the road and wanted to do more than just fix the body work and I heard that an MX5 engine near enough drops in and was thinking it would be an easy way to make more power and increase reliably tenfold. And with all the mod support behind the engine would be a good engine to work on when I get bored.
So over all, the parts its been thrown at it:
3 head gaskets
1 front wheel bearing
2 float needles
2 bottles of T-cut
A lot of WD40
EDIT: thread superseded by https://forum.triumphdolomite.co.uk/vie ... 0d2233468d
3 head gaskets
2 float needles
2 bottles of T-cut
A lot of WD40
- Car sat outside the garage
- image.jpg (344.83 KiB) Viewed 7520 times
Last edited by Boost All The Dollys on Thu Oct 29, 2020 2:43 pm, edited 7 times in total.
Re: 1500TC Resto-mod thread
Right, new plan
Ditches the idea of a Mx5 engine, going for an XR4x4 2.8/9 V6 with the 5-speed box AND 4wd gearbox
Get a hold of FWD hubs and spindles
Line the front diff that's attached to the V6 with the centre of the hubs
Put a 3.63 crown and pinion gear in rear axle
Remove gearbox cover
Fit engine and recover the gearbox cover
Make a dog leg set up for gear stick so it's in roughly the same place as triumph stick
Place handbrake lever somewhere
Rear disc conversation
Front disc upgrade
LSD in the back
Coil overs all round
Polybushes and updated springs
God knows how I'll do all the dials. I'm not too familiar with ford electricals and I'll maybe supercharge or turbo it if I want more power
Front disc upgrade
LSD in the back
Better plan, not using ford running gear and just doing an engine and gearbox swap. Jag 3.0 v6 to be precise. 240hp and 300nm got the 1800kg jag to 60 in 6.9 secs, in a car half the weight, I'm guessing 4-6 maybe, expecting mid 5s if I'm honestBoost All The Dollys wrote:Right, new plan
Front disc upgrade
LSD in the back
Re: Dolomite 1500TC with a jaguar 3.0 manual
Sounds like a mighty project mate and certainly one to watch, hats off for taking it on
All the best with it and keep us posted. That would certainly be the ultimate sleeper at the lights!!! Ive had an XJ with that engine...its no slouch!!!!
Kind Regards
Russell.
Kind Regards
Russell.
Well, that engine can get a 1800kg car to 60 as quick as an Fiesta ST which weighs 4-500kg less. So a car with that engine weighing 800kg less would be rapid.Dolly-Dimple wrote:Sounds like a mighty project mate and certainly one to watch, hats off for taking it onAll the best with it and keep us posted. That would certainly be the ultimate sleeper at the lights!!! Ive had an XJ with that engine...its no slouch!!!!
Kind Regards
Russell.
Got a car lined up, just waiting for storage as where I live isn't best suited for having two cars
Yes.......
I concur with Russell, it is an interesting project.
Personally I think you will struggle with all that power to control the car enough to get really quick acceleration from stationary
There was a Rover V8 powered Escort locally some years ago, it could only really be driven using third and top gears, but even then
only when driven carefully
Anyhow, I will be watching with interest.
Re: Yes.......
I hadn't actually considered that... it is a lot of power (more so even than the Rover V8), it propelled the significantly heavier jag along with considerable ease, I'm not sure how that could be harnessed in a controlled fashion but it will be an extremely interesting build, guess its all down to suitable gearing (or is there more to it than that - I'm not mechanically minded I'm afraid!!)sprint95m wrote:I concur with Russell, it is an interesting project.
Personally I think you will struggle with all that power to control the car enough to get really quick acceleration from stationary.
only when driven carefully.
Kind Regards
Russell.
Re: Yes.......
The diff ratio from the jag is 3.07 and the dolly is 3.83 so the gears might be a bit shortDolly-Dimple wrote:I hadn't actually considered that... it is a lot of power (more so even than the Rover V8), it propelled the significantly heavier jag along with considerable ease, I'm not sure how that could be harnessed in a controlled fashion but it will be an extremely interesting build, guess its all down to suitable gearing (or is there more to it than that - I'm not mechanically minded I'm afraid!!)sprint95m wrote:I concur with Russell, it is an interesting project.
Kind Regards
Russell.
Re: Yes.......
Got a jag bought to take parts from, it's a nice example and in manual form. Measured up the engine bay and it will fit nice and snug.Dolly-Dimple wrote:I hadn't actually considered that... it is a lot of power (more so even than the Rover V8), it propelled the significantly heavier jag along with considerable ease, I'm not sure how that could be harnessed in a controlled fashion but it will be an extremely interesting build, guess its all down to suitable gearing (or is there more to it than that - I'm not mechanically minded I'm afraid!!)sprint95m wrote:I concur with Russell, it is an interesting project.
Kind Regards
Russell.
The brake servo might need removed to make way so... Manual brakes for me then. Front brakes are going to be upgraded to twin pot calipers and maybe a tracker jack conversation on the rear
Coil overs and polybushes next on the list
Great news mate sounds like your making progress! Rather you than me though without a servo
It's either that or have the throttle body poking through the bonnet over the radiatorDolly-Dimple wrote:Great news mate sounds like your making progress! Rather you than me though without a servo
I'll see if I can pinch the jags one maybe
Either way its going to be some machine
It is possible to fit a remote servo. I'm sure there will be room for one somewhere.
Didn't know you could get remote servos, these a lot for £160 that looks like it will do. I just have to fit the engine to see where I can fit it.Toledo Man wrote:It is possible to fit a remote servo. I'm sure there will be room for one somewhere.
I'll add a list of parts that I'll be fitting:
Jag V6
Manual box
15x8 BBS RS rims with Semi-slick tyres (toyo R888)
Coil overs (dual adjust)
Uprated springs with a 1" drop
Polybushes
High ratio steering rack
LSD from Quaife
Wheel arch flares
Roll cage(in the future)
After I've done that and ran it for a few years, it'll be tore down and rebuilt
Sounds like you've got a plan in place
It certainly won't hang about
