I need to replace the worn switch for the heated back windscreen, it still works but can short out as it is being switched off .
Being on an early car, said switch is rather awkwardly located underneath the dashboard fascia so I am going to relocate it to
the gear lever console (a la T2000) which I know is a better location.
To reduce the strain on the switch I am going to wire it in using a relay.
So is this a worthwhile improvement?
thanks,
TDC Forum moderator PLEASE help us to maintain a friendly forum,
Anything with a reasonably high current draw, and an HRW is certainly that, is better off protected by a relay.
Ian, I'd be interested in this. When I fitted my early-type dashboard I lost the HRW switch. I agree that a relay is a good idea. Wiring it would be the same principle as the headlight relays. It might be a bit harder to keep the wiring runs short. I was thinking of fitting a switch plate under the dashboard to mount the switch but I like your idea. I was also considering using a Mini or a TR7 HRW switch either of which would be period perfect and would be in keeping with the BL "parts bin" philosophy.
West Yorkshire Area Organiser Meetings take place on the first Wednesday of the month at 8.00pm at The Railway, 1 Birstall Lane, Drighlington, Bradford, BD11 1JJ
2003 Volvo XC90 D5 SE (PX53 OVZ - The daily driver) 2009 Mercedes-Benz W204 C200 CDI Sport (BJ58 NCV - The 2nd car) 1991 Toyota Celica GT (J481 ONB - a project car)
