1974 Norwegian sprint
GTS290N
Re: 1974 Norwegian sprint
#166 Post by GTS290N »
Looking forward to seeing a video of the finished article. :D
Is this the only Dolomite in Norway?
Norwegian sprint
#167 Post by Norwegian sprint »
GTS290N wrote:Looking forward to seeing a video of the finished article. :D
Thanks alot :D
There is two dolomite sprint in Norway, mine and my friend's sprint. :wink: He also got a 2 door sprint converted toledo plus 4 big saloons. Both dolomite are french blue, mine imported from germany and my friend's imported from italy.
I have one question, it is about the clutch slave cylinder. It got a spring inside that push the pistion out.
This make the clutch release bearing in constant contact with the clutch pressure plate, and the result is that the bearing will constant spin when the engine run. Is this correct?
#168 Post by Jon Tilson »
Ah same Q as the f-b thread...
No - the spring only makes the piston return to contact with the push rod. Its not strong enough to push on the release bearing carrier.
If it does, you have the wrong spring.
Norwegian sprint
#169 Post by Norwegian sprint »
Jon Tilson wrote:Ah same Q as the f-b thread...
Hehe....yes the same question as FB-thread :bluewave:
I still don't understand how the clutch release bearing cannot be in constant contact.
After operating the clutch, the clutch pressureplate push the bearing back. But what force is pulling it away from contact? The spring inside is weak, but still stronger than "no power" at all :roll:
If I push the releasemechanism (and slave cylinder pistion) by hand back in, when releasing, the spring will slowly move the mechanism back until it stops when the bearing reach the pressureplate.
#170 Post by tony g »
I dont think it will be a problem. Even if there was no spring the pressure plate would only push the piston back just to take the tension off. The bearing will be just "kissing" the pressure plate and its doubtful it will see full engine rpm until you press the clutch. The saab concentric slave cylinder I have used on my sprint has quite a large external spring to hold the bearing onto the pressure plate in standard operation.
Norwegian sprint
#171 Post by Norwegian sprint »
tony g wrote:I dont think it will be a problem. Even if there was no spring the pressure plate would only push the piston back just to take the tension off. The bearing will be just "kissing" the pressure plate and its doubtful it will see full engine rpm until you press the clutch. The saab concentric slave cylinder I have used on my sprint has quite a large external spring to hold the bearing onto the pressure plate in standard operation.
That is what I mean, bearing is "kissing" the pressure plate, therefore in constant contact :wink:
Thanks for clearing that out :thumbsup:
On every other car that I've been fettling with, got at spring that pull the bearing away from the clutch.
(escort, cortina, mg....)
B.T.W....This must be the best forum in the world :bluewave: ....Makes me wanna to do another dolomite (sprint) :mrgreen:
#172 Post by Jon Tilson »
Isn't there a spring on the cross shaft that moves it back so the bearing doesnt stay in contact?
#173 Post by Mad Mart »
Jon Tilson wrote:Isn't there a spring on the cross shaft that moves it back so the bearing doesnt stay in contact?
There is a spring on said shaft but that is only for lateral movement.
Norwegian sprint
#174 Post by Norwegian sprint »
Joooohooo :jump4joy: ....wakeup call. :mrgreen:
Started on third try, run very well.
Have to sort out a leaking heating valve, guess it have to be exhanged to a new unit, or is it possible to repair?
Also no heat from heater. What is the correct heater hose routing? Guess the lower pipe into the heater valve is the heater input from the inlet manifold, and the upper heater pipe is return back to the waterpump?
https://youtu.be/Ij_T9xz9EzI
#175 Post by Jon Tilson »
I'm sure someone of your skills will be able to repair the heater valve after soaking in various chemicals and using
it in electrolysis etc...:-)
Its a pain to change the heater as the dash has to come out as well, but its not too bad. You can do the foam seals
on the various flap valves at the same time.
The hot side from the head or inlet manifold goes to the inlet of the heater and the return side goes to the water pump
cover. If the heater is off the water goes round through the link on the H pipe under the manifold.
Oh and it sounds good but I hope you didnt fill your house with fumes - rear end pointing at the garage.
Norwegian sprint
#176 Post by Norwegian sprint »
Jon Tilson wrote:I'm sure someone of your skills will be able to repair the heater valve after soaking in various chemicals and using
Hehe....thanks, the garage is used to get gassed :woohoo:
And the heater's input is the lower pipe where the heater valve is?
Cheers :thumbsup:
Norwegian sprint
#177 Post by Norwegian sprint »
Hello.
First testdrive done :wink:
The car feels very tight, brakes got superb power and "feeling", engine run smooth and feels powerful.
Have to fettling some more with the exhaust, touch the rear axle.
Proude viking writing this words :mrgreen: :woohoo: :woohoo:
CHEERS :spliff: :sozzled: :thumbsup:
https://youtu.be/9RDqYUhgKak
https://youtu.be/FMkh5LhYii0
Last edited by Norwegian sprint on Mon Feb 22, 2016 8:16 am, edited 1 time in total.
Pippin
#178 Post by Pippin »
Looks like someone left in a hurry! ;)
Norwegian sprint
#179 Post by Norwegian sprint »
EU- test ok (MOT).
Anyone know how many LHD sprint's made?
2016-03-20 16.52.50.jpg (466.13 KiB) Viewed 4751 times
2016-03-20 16.52.21.jpg (427.88 KiB) Viewed 4751 times
2016-03-20 16.50.37.jpg (416.53 KiB) Viewed 4751 times
GTS290N
#180 Post by GTS290N »
Stunning. Absolutely stunning. Well done.
