Im as novice as they get but me and a friend are really interested in buying a Dolomite. We saw a 1300 for £900 but the advert anoyingly was 3 months old (and already sold) so after searching around found a 1850 HL (http://www.carandclassic.co.uk/car/C696819#). It seemed great but when we checked the MOT history online it was a nightmare! Of the ten tests it took after 2006 it failed 6, it passed a test in April 2015 but then took another one in November of the same year (?) and failed, from what I think is a major problem.
Reason(s) for failure
Windscreen washer provides insufficient washer liquid (8.2.3)
nearside Headlamp aim too low (1.
offside rear Suspension component mounting prescribed area is excessively corroded jacking point (2.4.A.3)
offside Steering rack gaiter split (2.2.D.2d)
nearside Front wheel bearing has excessive play (2.5.A.3c)
also
Advisory notice item(s)
offside Front wheel bearing has slight play (2.5.A.3c)
nearside front Brake pipe slightly corroded (3.6.B.2c)
offside front Brake pipe slightly corroded (3.6.B.2c)
Steering system has slight free play detected at steering wheel (2.2.A.1b)
all indicators flashing slightly slow
It passed a test on the 20th of April so I guess by default it still has an MOT till April 2016. I am going to see the car on Saturday (5 days time), would you guys suggest I buy this car and if yes what should I look out for? My main concern was the jacking points, it seems an expensive fix but also a safety concern. We're both students so don't have a garage/time/knowledge to do any repairs ourselves and were kinda hoping this could be be an interesting but reasonably cost efficient first car. The cars priced at £1500 ono and the insurance for us was £600 so it seemed on par with a more modern car, could the issues be sorted for less than £500 (our max budget was £2300)?
it was a bit of a ramble but if you do read through any advice would be greatly apreciated.
