Double Valve Springs
reychris
#1 Post by reychris »
Hi all,
About to start recommisioning a rally spec sprint engine and one of the things to replace are the valve springs as it hasn't turned over in many a year.
Currently it has a Piper BP300 cam and double valve springs.
Can anyone tell me where I can get new double springs from?, have tried Piper, Kent, Rimmers etc but with no luck.
Chris
Ron1966
Re: Double Valve Springs
#2 Post by Ron1966 »
If they are serviceable Chris I would leave well alone because they are probably better quality than some of the rubbish about now.
#3 Post by Mad Mart »
Try Ken Clarke Motorsport.
01455 616617
#4 Post by soe8m »
I would not use them again. Too much strain on the chain and tensioner and very not needed in a sprint.
Ron1966
#5 Post by Ron1966 »
Lots of good advice and knowledge on this site Chris from people who have first hand experience of uprated Sprints like Jeroen and Mart. Anyway welcome to the forum.
bodgerben
#6 Post by bodgerben »
Burton's - if you really need doubles look at their Sierra Cosworth range - they fit.
Rally engine - good quality singles may be your best bet (again, size up a set from Burton's and check for coil gap at full lift).
Or phone/email Ken Clarke or Rob MacGregor (SprintSpeed) and find what they use.
Singles are fine for 7.5k
reychris
#7 Post by reychris »
Many thanks for the info, will try those leads.
Didn't know that Sierra cosworth springs fit, what did we do before forums were invented!?
#8 Post by Carledo »
reychris wrote:Many thanks for the info, will try those leads.
STRUGGLE!
lazeruspete
#9 Post by lazeruspete »
:lol:
viewtopic.php?f=19&t=23031
Proud TDC Member!
DF
#10 Post by DF »
Unless your reving the nuts off the engine singles will be fine
If you can find some lighter valves even better ,
