Keys info for locks etc
simonhorton
#1 Post by simonhorton »
How many different keys did the cars have
Was same key used for ignition and doors and boot ?
Many thanks
Re: Keys info for locks etc
#2 Post by tony g »
One for doors One for ign one for boot and glove box ive got
RJF_70
#3 Post by RJF_70 »
On both my cars it has one for doors & ignition, one for boot , one for fuel cap. Leyland key for doors and igniton so presuming this is correct? :?
1981 Dolomite 1500 Auto
#4 Post by tony g »
Rich is the door key the same as ign on yours or 2 keys one for each?
geeksteve
#5 Post by geeksteve »
Door key *should* be the same as the ignition... Mine are not. The door accepts anything but the ignition key. You can open it with a teaspoon, but if you put the ignition key in it wont work.
RJF_70
#6 Post by RJF_70 »
Yes Tony both operate from the one key, doors + ignition!
Rich..
#7 Post by Toledo Man »
Boot & glovebox "should" also work on the same key.
simonhorton
#8 Post by simonhorton »
Thanks for all the replies :)
Mines a 1973 car , just read that ignition key does door locks
Seperate key for boot
Seperate tiny key for glove box
Simon
markas
#9 Post by markas »
simonhorton wrote:Thanks for all the replies :)
Simon
As has been said above, same key should work door locks and ignition. The boot & glovebox should be the same key - a Willmot Breeden FS type. None of the cars were supplied with a locking petrol cap but a Unipart accessory cap was often fitted. I've got one of these, it's the only lock on the car which doesn't work!
1980 Dolomite 1850HL Auto
1977 Dolomite 1500
