However, I can't find the earthing point for them.
As far as my electrically challenged eye can see from the wiring diagramme, both sender units are earthed and there are no other earthing points near the gauges.
BUT....There is only 7 volts getting to the fuel tank sender unit. The battery has a reading of 13+ Volts.
Every other earthing point, that I can find, checks out OK.
Where should I look in order to fix this %$@#*&) annoying problem?
Cheers,
Rob
