wiring loom tape
simonhorton
wiring loom tape
#1 Post by simonhorton »
Hi everybody,
I need to re tape my engine bay wiring loom
What's the best to use ?
Thank you
Flyfisherman
Re: wiring loom tape
#2 Post by Flyfisherman »
Simon
The modern tape (black fleece tape http://www.autosparks.co.uk/electrical- ... -long.html) probably the best - but if need to gain access to the wire its a sod to remove.I have used this tape http://www.autosparks.co.uk/electrical- ... -long.html
Paul
SprintMWU773V
TDC Staffs Area Organiser
#3 Post by SprintMWU773V »
The autosparks tape is if I recall non-sticky, it just sort of sticks to itself. Normal insulation tape is horrible and nasty sticky stuff that's fine for emergency situations but otherwise horrible to remove.
Magenta Auto Sprint
#4 Post by Magenta Auto Sprint »
I used bondelec tape, which you can buy from Holden classics,
I have 90% of my roll left if you're interested
Malcolm
#5 Post by soe8m »
The original non sticky tape. Adhesive tape will make the loom less flexible.
simonhorton
#6 Post by simonhorton »
Many thanks for all the replies
Also does the starter motor lead from the battery clip onto the subframe , where abouts please
Many thanks
Simon
Flyfisherman
#7 Post by Flyfisherman »
Simon
On the back side of the front cross member of the sub frame three are two holes for a retention clip similar to the brake pipe clips
Paul
simonhorton
#8 Post by simonhorton »
Hi Paul,
Do you have some pics please
Many thanks Simon
Flyfisherman
#9 Post by Flyfisherman »
Simon
The clips you want are these:
http://www.rimmerbros.co.uk/Item--i-624155
Same clip thats used to the fuel / brake lines
Paul
simonhorton
#10 Post by simonhorton »
Many thanks :D
