I've just realised that I've installed new NGK plugs into my SPRINT with the book recommended gap. Considering it has a Pertronix Ignitor electronic ignition system fitted, I understand they will require a wider gap. I have no idea how much wider, so, what would you recommend?
Also, since a wider gap means a bigger spark, does that mean the spark will be hotter too? Will this be detrimental to extended running and steady engine speeds at around 100-110kph?
Thanks & Cheers,
Rob
Plug gaps with electronic ignition.
Re: Plug gaps with electronic ignition.
I think the figure for Lumenition ignitions was 35 thou ( instead of the 25 thou ) so maybe start from there or look on the pertronix website to see if they have a recommended figure
35 thou is about right for most electronic ignitions,. Much bigger and you tempt the spark to track out.
Thanks for answering.
I checked with Pertronix who reckon about 5 thou extra (.030) would be OK.
You gents reckon about 10 thou (.035) is the go, so I went somewhere in the middle and set them at 32 thou.
I immediately took it on a run and found that I could hear an increase in induction noise, and the engine felt somewhat more responsive.
BUT, will this mean that the engine will run hotter?
Thanks again and Cheers,
Rob
Rob
Only if your cooling system is unable to loose the extra energy from better combustion.....
