Evening all, it's time to balance some rods!
First of all, thanks to Mart for introducing me to this, it has been a really enjoyable and I have learnt something new at the same time. Rod's arent that cheap but are cheaper than pistons so if I balls it up then at least I can get a new one!
For those of you who don't know what I'm up to here, what I am doing is ensuring that both the rotating weights and reciprocating weights are the same. To do that I need to weigh the small end of each rod and remove material as necessary to ensure that they are all the same. To do this you need a rod balancing Jig. They arent easy to find in the UK, I have this one from Amazon.com
http://amzn.com/B000A8J5OY when buying one of these you need to ensure that all of the joints have bearings in to reduce any friction. Friction will translate into inaccurate weight readings. You'll also need a good accurate set of scales that measure down to 0.1 grams. eBay is good for this, mine cost about £8 with some calibrating weights. I checked its accuracy when it arrived and it's bang on.
In terms of going about doing this, I basically followed what the guy does in this Youtube video
https://www.youtube.com/watch?v=QLpiF0E0EJU and looked at Jeroens thread here
viewtopic.php?f=4&t=28355 on where to remove material.
The first thing I did was to weigh each rod and establish which one was the lightest.
The trick here is to ensure everything lines up and the rod sits horizontal. I taped the jig to the scales to minimise the risk of me knocking it all out of alignment. It takes some practice but I was able to take the rod on and off and have about 0.1g a difference per 10 goes.
Number 1 was significantly lighter so I put that to one side and noted down the other weights, on average I needed to remove about 6 grams from each small end.
I ended up having to remove quite a lot of material from the small ends, almost as much as Jeroen in his build.
I used a combination of a grinder, flap disc and a belt sander to remove material.
Small ends done.
The big ends are a bit easier, as the small ends are all the same weight any difference in the total weight of the rod would just come from the big end now. So it's just a case of weighing everything and taking material from the cap to adjust as required.
Number 1
Number 2
Number 3
Number 4
As you can see with a few trips to the belt sander I managed to get the total weight of each rod to within 0.2g of each other.
Then just as a double check I weighed the small ends again to ensure that I had done them properly.
Number 1
Number 2
Number 3
Number 4
The small ends are all within 0.1g of each other. I was trying to get everything within 0.5g so with the accuracy of the scales I should be well within that so I'm very pleased with the result here, this did take me all afternoon though so don't think it's a 5 minute job!!
The oil feed hole needs the countersink opening up, I need to get a bit to do this other than that they are done.
Just need to sort out the pistons now.
