Club front wheel bearing kits
Are they in stock and what make are they? Anyone know? Need 2 sets
Re: Club front wheel bearing kits
No Tony, none in stock I'm afraid.
tony g wrote:ok cheers Mart
Hi,
I got to from below, quick and helpful, The come in Fleet line packaging, the bearings seemed reasonable for the tenner I paid.
http://www.angclassiccarparts.co.uk/hom ... t-dolomite
Aberdeen
Cheers, Ive seen plenty on ebay etc just thought if the club had some Id go for them.
James Shackford has them...."Triumphstuff" on the bay, decent stuff from a decent bloke.
I got a set of British timken which were original ly fitted from Chris Witor. Be careful of Chinese or Russian copies. tractor boy
As Tractor boy said.I bought some from ANG,and found I had to adjust the bearing,4 times in 20 miles!Bought some Timken ones off ebay,and was going to fit them,when(sods law) the ANG ones settled down.I might add, I have had a lot of stuff off ANG and never had any issues.I think its probably the bearings they have been supplied with.Stick to Timken,RHP or Koyo,well known brands.
Thanks guys. Ive found a timken set on ebay new old stock and a 35 year old Toyo set both of which im happy to use
I can't confirm this ATM but i've heard the Dolomite front bearing is the same as the GT6 one, which would, if true, open up a lot of possibilities.
Its the same as T 2000 etc as well so I imagine theres a few options. There are lots about but I wanted some names I knew. My 2 kits come with a new felt seal too whereas some kits are just bearings
The ANG fleet line bearings complete with seal and two types of split pin and a packet of grease, bargain!tony g wrote:Its the same as T 2000 etc as well so I imagine theres a few options. There are lots about but I wanted some names I knew. My 2 kits come with a new felt seal too whereas some kits are just bearings
Aberdeen
