Oil Transfer Housing
andrewwild
#1 Post by andrewwild »
Hoping someone can help me.
Was supplied with a new oil pressure switch from Rimmers, it looked exactly the same but after closer inspection now it is slightly longer thread, unfortunately it cracked the transfer housing and oil is now leaking everywhere, I've discovered these are hard to come across, Stanpart 214020.
Does anyone here have one spare they would be willing to sell?
Many Thanks, Andy
Magenta Auto Sprint
Re: Oil Transfer Housing
#2 Post by Magenta Auto Sprint »
the thread on the oil pressure switch is a 3/8 unf tapered thread, you don't need to screw it all the way in, just until it is tight.
you could have the hole welded up and drill and tap the second boss on the cover, this would save the cover.
malcolm
Galileo
#3 Post by Galileo »
James Paddock has one 'listed', but of course might not actually have one but maybe worth a call, as would be TD Fitchett if no TDC bods have one lying around:
214020U OIL TRANSFER HOUSING GOOD USED £8.50
simonhorton
#4 Post by simonhorton »
Hi Andy
I have a transfer housing
Simon
Karlos
#5 Post by Karlos »
Magenta Auto Sprint wrote:the thread on the oil pressure switch is a 3/8 unf tapered thread, you don't need to screw it all the way in, just until it is tight.
malcolm
Isn't it 3/8 BSF? Good idea though to get it welded up at a local fab shop that does aluminium welding.
GTS290N
#6 Post by GTS290N »
Scrapping an 1850 block soon, let me know if you need the housing.
Dolly racer 33
#7 Post by Dolly racer 33 »
The thread on the oil pressure switch is 1/8 NPTF.
