Dolomite sprint kit car
longboarder
#1 Post by longboarder »
Spring has sort of sprung, so I got the old sprint kit car out and took it for a shakedown. Pleased to say that apart from the overdrive switch failing everything went great. BUT, yeah there is a but, I noticed it seemed a little "coarse" while under heavy throttle, cruising and easing along great, but on long empty hills when I put the hammer down it went, but felt a bit rough, but it went. Could it be stale fuel? been in the car all winter and I did top it up in the morning. As a postscript I fixed the overdrive switch last evening, its now all cleaned out and rewired, works a treat. Here is to a good summer of Sprinting.
Re: Dolomite sprint kit car
#2 Post by Jon Tilson »
Old fuel....
Definitely helps to get new stuff in.... I leave my old heaps with just enough to get to the garage after the first shakedown...
This was a bit of an issue when the Sprint decided to stick its clutch though.....I ran out of fuel freeing it off.
longboarder
#3 Post by longboarder »
got some help
m_my dutton10.jpg (56.53 KiB) Viewed 630 times
#4 Post by soe8m »
She uses the same spanner as i alway's do to adjust the carb to airfilterbox clearance.
longboarder
#5 Post by longboarder »
:lol: :lol: you spotted it !
