We love it loud.....
#1 Post by sprint95m »
Since I had the grills removed anyway for access to run wiring to daylight driving lights, I decided to wire in the Dolomite's
horn via a relay ( I seem to have loads of secondhand relays).
This was simple enough, run a heavy wire from the additional fusebox to a relay located by the horn, swap a couple
of wires onto the relay and earth the relay.
:) The horn is now way louder than it was before.
Mahesh
Re: We love it loud.....
#2 Post by Mahesh »
Now that's worth doing.
The horns on my Sprint are a bit feeble.
#3 Post by Mad Mart »
Mahesh wrote:Now that's worth doing.
You can adjust them.
#4 Post by Toledo Man »
I found this out when I finally sorted my horn problem. I could only get one or the other working but not both together. This was fine for the MoT so I just lived with it for a long time (like a few other things). I took them off and put 12v to them in turn and twiddled the adjuster until I got a decent sound. Once they were back on the car they worked exactly as they should.
Mahesh
#5 Post by Mahesh »
Hmm, something more to fiddle (adjust).
