Mahesh
#556 Post by Mahesh »
Typical,
I know its sacrilege, but the aftermarket jobs just don't look right,
#557 Post by Jon Tilson »
Aaaargh!.
Oh well they are fairly common....so an e/window conversion for you then...
Or you could do a different speaker location like the trim under the front parcel shelf at the sides...
Mahesh
#558 Post by Mahesh »
Needed a bit of rounding off,
Used a washer to marker pen the handle,
2016-05-12 16 33 09.jpg (220.82 KiB) Viewed 521 times
Unfortunately, I don't have a bench grinder and an engineers file is too slow,
#559 Post by tony g »
:thumbsup:
Mahesh
#560 Post by Mahesh »
Getting better at handle chopping, second and last one, and therefore I encounter a problem,
The e-clip retaining flare did not survive the extraction in a good way and is flaking off,
Now either I heat up the shaft and hammer it, but the knob will not survive, or I drill the
shaft center and screw in a washer, third option get another handle and start again,
unless anyone can suggest otherwise?
James467
TDC Sprint Registrar
#561 Post by James467 »
Install electric Windows! :lol:
Mahesh
#562 Post by Mahesh »
I have considered that, but the handles do look nice,
If electric is done later, I will use the existing plastic escucheon and put in a
chrome toggle switch in the center, only prob is it means another door to frame
grommet which in turn means more holes.
Alternatively, these would fit,
door handle.jpg (36.6 KiB) Viewed 488 times
window handle images.jpg (28.87 KiB) Viewed 488 times
Would be a pain to wind/unwind the window.
And it's NOT GOING TO HAPPEN!
James467
#563 Post by James467 »
Awwwww but they would go so well with those neon hoses!!! :lol:
#564 Post by tony g »
Can you run a hacksaw cut around the groove and fit a smaller clip?
oily66
#565 Post by oily66 »
Can you drill a small hole through the spindle then put a washer on and a split pin or something of that type to secure and keep the rotation?
Trevor
2017 Jaguar XE R-sport
#566 Post by Jon Tilson »
Or stop messing up handles and door cards and stick the speakers somewhere else....
(sorry)
#567 Post by Carledo »
I have a universal electric window kit for my Sprint (front only) A mate bought it for his Defender about 20 years ago and never fitted it. The Defender is long gone so I got the kit for free!
So I guess I can spare you a couple of handles!
I'm toying with the idea of using the entire loom from the Omega on my car, it may be a bit on the large side but that's better than being too small! And it has wiring and grommets and stuff for 4 door speakers, electric windows, central locking, courtesy lights etc etc etc/
Mahesh
#568 Post by Mahesh »
It's only two handles, I bought the door cards
with the cutouts from a club member (honest).
The front doors are the best place for the speakers,
unless you suggest otherwise (on the other hand
don't make a suggestion :!: ) or was that the suggestion)
On the plus side I have done the front doors remote
central locking, useless for security but does stop
the keys clanking and scratching up around the locks.
Mahesh
#569 Post by Mahesh »
Thanks Steve,
I'm ok for handles at the moment, was the Omega central locking individual electric solenoids or BMW type with a central air pump, just curious.
Door grommets can be a pain, door side easy, frame not so.
2016-05-13 20.53.39.jpg (102.88 KiB) Viewed 796 times
Mahesh
#570 Post by Mahesh »
Gone with Tony's recommendation of another hacksaw cut, but I had to make the goove below the
original yet close as possible to the top of the shaft,
not the best of pics,
got an e-clip in, (original flew off) somewhere)
and the end result is a stubby originalish window winder handle,
Probably won't last that long.
