Mahesh
#631 Post by Mahesh »
Finished with the top now, all that remains is the seal, and whether to cut the new glassmat to the same size
as the old pad or go full coverage.
#632 Post by Jon Tilson »
Wow that looks so shiney its a shame to cover it up.....
Did you polish it? How long did it take.....
I love it....
Mahesh
#633 Post by Mahesh »
Even I was impressed, unfortunately not polished,
End of line cheap can from £+ shop, £2.99,
I'm useless at spray paint, but find the cheap stuff is more forgiving.
Mahesh
#634 Post by Mahesh »
Inspired by Flyfisherman, I used a neoprene spongy seal, but in order not to break tradition, as always, overdone,
2016-06-03 20.39.26.jpg (85.83 KiB) Viewed 1329 times
25mm wide x 15mm thick, but it does compress down to 4mm.
Bulldog clips temporarily loaned from someone :)
GTS290N
#635 Post by GTS290N »
I like the bulldog clips.
No, seriously, I love that tunnel, brilliant improvisation it's awesome.
#636 Post by Jon Tilson »
My only concern is that you can force it down low enough to get the little studs to line up. I can see that seal being a bit thick....
Then of course you have to compress the front edge enough to pull the horizontal holes in to alignment. They are only spire clips and even with
the old seal Ive had studs snap off and spire clips give way. So best of luck with the refit....:-)
Wow that paint is excellent....
SprintMWU773V
TDC Staffs Area Organiser
#637 Post by SprintMWU773V »
Starting to think I should have painted mine a different colour. Currently it's satin black!
#638 Post by Toledo Man »
Mark, you should see the colour of his cooling system hoses!
Mahesh
#639 Post by Mahesh »
J nuts for the tunnell are pretty buckled to begin with, and I can only find J nuts in smaller sizes, U nuts (clips}
are no problem.
For the thick seal I have ordered some M6 U clips which should allow me to use longer bolts initially and then change
to shorter ones.
Mahesh
#640 Post by Mahesh »
Put the glassmat on, still have to trim some,
2016-06-07 21.13.45.jpg (137.65 KiB) Viewed 1230 times
Looked better before
Pippin
#641 Post by Pippin »
It seems a shame to cover up the mirror finish you'd previously achieved!
Mahesh
#642 Post by Mahesh »
I know, loved the previous look, but the carpet is inevitable.
#643 Post by Jon Tilson »
Why not go for a new style "iron man" interior and some lime green rubber bits to match?
Mahesh
#644 Post by Mahesh »
One of the tags did not survive the bending, other than a new switch solder is the only answer.
A small rubber cover with solder should suffice.
shaunroche
#645 Post by shaunroche »
Is that a 2nd gear overdrive switch I see?
