sprint backplate bolt size
cleverusername
#1 Post by cleverusername »
The sprint engine I am rebuilding came without a backplate, I have one, but no bolts. I now have the pistons in and the siezed engine now turns with new rings and bearings. However I have no way of screwing the backplate to the engine. Does anyone know the correct bolt size?
Re: sprint backplate bolt size
#2 Post by Toledo Man »
You will need 4 x HU856 (5/16" UNC and 3/4" long) and 2 x HU857 (5/15" UNC and 7/8" long). The washers are WP8.
Hope this helps.
Edit: Those are for the back plate on the cylinder head. For the engine block back plate you will need 6 x HU0806 (5/16" UNF and 3/4" long), 4 x HU0815 (5/16" UNF and 1 7/8" long) and 3 x HB0818 (5/16" UNF and 1 7/8" long).
Sorry for any confusion!
#3 Post by Mad Mart »
There are only six bolts holding the backplate to the block. These should not have any washers of any type on them so you should use some thread lock on the bolts.
cleverusername
#4 Post by cleverusername »
Thanks, will order, shame you can't buy imperial bolts in a shop anymore.
Following assembly instructions in the little book of lies. It says backplate, flywheel, timing gear and then cylinder head in that order.
#5 Post by Toledo Man »
You should be able to get the correct bolts from a few of the usual suspects.
#6 Post by Jon Tilson »
Note that the backplate location bolts have to be in different places for manual and auto cars.
If you put them in the right place for a manual car they foul on the torque converter to flex plate bolts.
Okay, as i have said before.......
#7 Post by sprint95m »
cleverusername wrote:Thanks, will order, shame you can't buy imperial bolts in a shop anymore.
Marine, agricultural and commercial machinery suppliers all do.
