Dolly Sprint Suspension spring height
Hobo
#1 Post by Hobo »
Does anyone have the spec for the height of both front and rear suspension coil springs chaps?.
I was given what seem to be various new coil springs that came from France but have no idea as to the spec. I don't have any old coil springs to compare them with.
Not sure of the rating either, the coil springs are white, but as we know this means nothing as they may well have been re-coated.
Flyfisherman
Re: Dolly Sprint Suspension spring height
#2 Post by Flyfisherman »
Hobo
Unsprung (not under any tension) lenghts are as follows for a sprint.
Fronts = 360mm
Rears = 290mm
Paul
Hobo
#3 Post by Hobo »
Thanks Paul :wink:
Hobo
#4 Post by xvivalve »
Hobo
#5 Post by Hobo »
xvivalve wrote:So who is right for the fronts?
viewtopic.php?f=4&t=30793&p=287808&hili ... hs#p287808
Does anyone have access to Technical data Alun?
