Monroe Radial Matic 3270
#1 Post by xvivalve »
Any one able to give me a cross reference or application for this please?
Re: Monroe Radial Matic 3270
#2 Post by xvivalve »
^ bump
#3 Post by tony g »
what type of shock is it Alun, do you have a pic?
#4 Post by xvivalve »
It has a bushed eye at one end, a thread at the other and has no spring seat.
#5 Post by xvivalve »
#6 Post by tony g »
Its a very high number for eg manta rear is 1566 and I remember fitting a lot of monroe shocks years ago but that number seems odd to me. Is it 100% correct (the number that is)
#7 Post by tony g »
Found an online catalogue and it says discontinued but I guess you knew that :)
#8 Post by xvivalve »
I must have found the same on line catalogue!
Marina ones were 3258, maybe they renumbered?
R3270 is printed on the box and stamped on the tube...
red&black
TDC Notts,Derby & Leics Area Organiser
#9 Post by red&black »
The cross reference section of my 1988 Unipart catalogue goes straight from 3269 to 3271.
3269 is for Alfasud and 3271 is for Simca 1000,so they don't appear to be grouped together by manufacturer.
Sorry...
James
geeksteve
#10 Post by geeksteve »
Might be able to identify it by measuring dimensions?
#11 Post by tony g »
Alun are the 3270's stud for the top or bottom? (fatter part being top) Marinas are eyelet top and stud bottom and the fiat type you posted the link to are opposite. May help narrow it down a bit :)
Galileo
#12 Post by Galileo »
Vauxhall Victor.
#13 Post by xvivalve »
Studs are on the thicker part.
Vauxhall Victor eh? No wonder they are superseded! I wonder if they then also fit the VX 2200 range as Ted's brother had a GLS version of that...
Thanks Raf, do you have an old catalogue or something?
Galileo
#14 Post by Galileo »
Thought I'd put a question mark at the end of that statement! I'd emailed Dom the mechanic and that was the response, but it doesn't work in reverse when double checking what he said on the Monroe site just now, mind you maybe they've changed their number?
Edit: Wondered what google would come up with, and lo and behold on ebay http://www.ebay.co.uk/itm/VAUXHALL-VICT ... 1481591835, do they look like yours?
#15 Post by xvivalve »
Excellent, I've been searching ebay on and off (under the part number) for a while now and that never came up!
Meanwhile, I've ascertained that the same part is common to some Victors and some VX 4/90 models.
Thanks for all inputs.
Alun
