Now, I've got a mate who is a MOT tester, but I like to not mix business and friendship so I use a village garage to do my MOT's and emergency repairs. Anyway, nothing that concerning, and they were very complimentary about the overall condition of the car and walked me through the failure points, but I've just noticed an advisory which he hadn't mentioned, so just making sure that you would read this as steering rack wear rather than TRE?
Reason that this interests me is that I have never managed to get rid of a steering vibration at speed, right smack bang in the 65 to 75mph range, lower or higher** is fine. Would replacing the steering rack be a good use of my money?Reason(s) for failure
Parking brake: efficiency below requirements (3.7.B.7)
rear Brakes imbalanced across an axle Axle 2 (3.7.B.5b)
Brakes imbalanced across an axle (3.7.B.5b)
nearside rear rear brake recording little or no effort (3.7.B.5a)
offside Headlamp not working on main beam (1.7.5a)
nearside Track rod end ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.2.C.1c)
offside Steering rack gaiter split (2.2.D.2d)
centre Exhaust system not adequately supported (7.1.1)
Advisory notice item(s)
Free play in both ends of steering rack
I know what all of the brake issue is, oil or grease leaking into the hub, smells like grease rather than diff oil, but I read on here that it is very rarely the grease seal?
Ta for any thoughts!
*Had a great weeks sea fishing and chilling, lots of abandoned WW1/2 buildings dotted around what was the main base at Lyness overlooking Scapa Flow for the Royal Navy until finally closing in 1957, fascinating to explore.
**Tested off public roads officer.
