Gearbox change
Re: Gearbox change
Did you measure the pushrod in your master cylinder?
Re: Gearbox change
Yea it's around 70mm.
My local car shop is thinking theres 2 different slave cylinders
Re: Gearbox change
There are more than two slave cylinders....
They must go with the right bracket....
Re: Gearbox change
This is the housing fitted to the gearbox if that narrows it down ?
- image.jpeg (20.67 KiB) Viewed 820 times
Re: Gearbox change
This looks like an adaptor ring, according to the sprint workshop manual (33.35.07), the slave cylinder has a built in flange, so your flange is made to use another slave cylinder of similar performance, but bore sizes, travel and master cylinders need to be matched for fluid displacement.
see below
http://www.angclassiccarparts.co.uk/hom ... 0hl-sprint
Malcolm
see below
Malcolm
Re: Gearbox change
That slave cylinder only does the 1850 and sprint,
My car is a 1979 1500hl, the slve cylinder on mine pushes into that bracket and is secured with a pinch / lock bolt .
Re: Gearbox change
Apologies, I forgot we were talking about a 1500HL, I had sprint at the back of my mind.
malcolm
malcolm
Re: Gearbox change
Indeed and those brackets and slaves are not all the same...
But they all have the pinch bolt and groove so look interchangeable, but they arent.
The Volvo 140/240 series have a similar design too, which may well lead to some eroneous mixing and matching.
When you add Spits and heralds into the mix and the dolly 1300 and 1500 with different clutch plates its a nightmare...
Re: Gearbox change
Don't know if this will help but some suppliers use a Land Rover Series slave cylinder for Dolomites. Presumably the pushrods could be different.
Re: Gearbox change
Again for 1850's but the unions are the wrong size...
Re: Gearbox change
Does anyone know the difference between these cylinders ?
i.e bore sizes ,length ?
