Welcome to the forum.
There isn't a simple answer. You will need to take into account how you will be using the car, what your budget is and your skills. Do you want a project, a good car (restored or original) or something in between (an abandoned project which is 90% done or suchlike)? You've already come to the right place and it is worth joining the club to take advantage of the benefits on offer. Try to attend a local meeting if you can then you can see what the cars are like.
You seem to be aware of the rust issues (all cars of the same era had the same problem). Electronic ignition is worth considering and has improved reliability no end on my 1850. There are some poor quality parts so it is worth paying that bit extra for decent quality. Overdrive makes for more relaxed top gear cruising so it is worth getting a car with overdrive if you can. It was the 1500HL, 1850/1850HL and Sprints that could be specified with overdrive from new although some owners have retrofitted an overdrive gearbox to the "lesser" cars. I helped out on such a conversion on a 1500SE about 10 years ago. Automatics are worth considering and the general consensus is that the 1850 is the best combination with the automatic transmission. The transmissions are quite reliable and the only problem is that the flexplate can break in the middle (I've had it happen to me twice in the 8 years I've owned my 1850 auto) which means the engine and transmission have to be separated to replace the flexplate.
Hope this helps.
1972 Dolomite 1850 auto (NYE 751L - The rolling restoration)
2008 Citroën C4 Grand Picasso 2.0 HDi Exclusive (MA08 WCL - the workhorse)
1995 BMW 318i (M265 PNC - Project Bimmer, the weekend car)
1991 Toyota Celica GT (J481 ONB - the new project car)
Check my blog at
http://triumphtoledo.blogspot.com
"There is only one way to avoid criticsm: do nothing, say nothing and BE nothing." Aristotle
