Fitting gutter trim
Fitting gutter trim
Struggling to fit the gutter trim, does anyone have any suggestions?
Thanks.
Thanks.
Re: Fitting gutter trim
Get a nice thick glove and whack it on with the heel of your hand.
This is an absolute pig of a job. That's why I left mine on and carefully masked it when I did the respray.
Yes easy but to add start with the bend above the a pillar.Carledo wrote:Get a nice thick glove and whack it on with the heel of your hand.
What year is the car? You may need the unobtainable clips!
I've only ever seen the clips on factory vinyl roof cars (ie Sprints) Even then, they don't seem to be essential, I think they hold the vinyl in place till the brightwork is fitted!James467 wrote:What year is the car? You may need the unobtainable clips!
I have a full car set of clips but they are NOT for sale, at least at the moment! Incidentally, where fitted, there are 2 different ones, the very front one on each side is different from all the others!
Don't worry Steve I have a full set including both types!I have a full car set of clips but they are NOT for sale, at least at the moment!
Paul, I thought they were fitted to the later cars which is why I asked.
- SprintMWU773V
- TDC Staffs Area Organiser
I also removed all my clips from my car. I'm not convinced they are necessary but kept them just in case.
Guessing well aimed and gentle use of a light rubber mallet may also help in fitting them.
No its NLA
I do have at least one pair of mint gutter trims spare that I could be persuaded to part with, but they would obviously have to be collected as they are much too fragile to commit to the postal system! And couriers charge upwards of £50 to ship anything over 2m long!
I fitted mine back after the respray with tiger seal and g clamps to hold it while it dried..
That's a bit permanent for my taste! They'll certainly never come off again, I glued the GRP wings and front panel onto the Carledo with Tiger Seal, they have been on for 4 years now and survived 2 minor collisions, one from an Audi with a badly applied handbrake that rolled into it whilst parked on a hill last year and the other last Friday from the Jaywalking dog. All the seams are still tight as a drum!matt of the vivas wrote:I fitted mine back after the respray with tiger seal and g clamps to hold it while it dried..
Tigerseal is simply amazing.
I have a problem with the rear of my nearside gutter trim coming detached, resulting in it flapping in the breeze. I have been contemplating using a small pop rivet at the rear end.
Anyone else had this problem and how did you fix it, without Tiger Seal?
Tim
Tim
Tim Edwards
