Sprint valve clearances.
sprintchris
#1 Post by sprintchris »
Hi,
I shall be reassembling my Sprint engine soon, I have a new Kent fast road cam to go in, I'm wondering if the valve clearances should be set to that of a standard cam or if it's different.
Some advice would be gratefully appreciated.
Thanks in advance,
Chris.
Re: Sprint valve clearances.
#2 Post by Jon Tilson »
On a Kent fast road its similar to an STR91. What is the timing? Do you know the number of the cam ?
If its 106 ATDC then its 8 inlet and 9 exhaust....like mine.
#3 Post by soe8m »
0,15 in 0,20 ex. gives a nice quiet engine. There's a direct valve operation and no pushrods involved so it can be adjusted much narrower than the data from "the books".
Triumph1300
#4 Post by Triumph1300 »
Do you mean mm Jeroen? 15, and 20 thou if an inch seems a bit wide?
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
#5 Post by tony g »
Yes he means mm .15 being 6 thou and .2 being 8 thou, but you knew that Bruce :)
trackerjack
#6 Post by trackerjack »
Yes he does mean .015" and .020" because I recall running it past Jeroen before I set the engine valve clearances on the various engines I have built recently after noting that Sprints tap like Fred Astaire and other cars like Hillman Imps and Ford twinkies that use the same method have much tighter clearances than Triumph recommend. The bonus is quieter engine and slightly more power. 8)
dursley92
#7 Post by dursley92 »
Sorry but I'm confused now folks. There appears to be two contradictory recommendations here.
What is the suggestion for a standard Sprint?
Is it 0.015" and 0.020" in old money because I was working from the factory manual which specifies 0.018" for both?
Russ Cooper
Dursley
UK
#8 Post by Carledo »
Sorry Russ, Jeroen, being of the Dutch persuasion, thinks in Metric and any figures you get from him are in mm, NOT thou!
I believe his experience suggests you can get away with 6 thou (0.15 mm) inlet clearance and 8 thou (0.20 mm) exhaust, even with a standard engine.
Like me, Jon is getting confused in his old age!
#9 Post by soe8m »
Mm.
#10 Post by Carledo »
soe8m wrote:Mm.
See, he's thinking again ^^^^^^^^^!!!!!! Some say that............................
trackerjack
#11 Post by trackerjack »
Well I am an old man now and of course suffered a brain injury last year.
However I hang my head in shame because its .15mm in and .2mm ex.
I just wrote quickly without too much thought :roll:
No one would believe I am a toolmaker and am measuring stuff all day :oops:
dursley92
#12 Post by dursley92 »
trackerjack wrote:Well I am an old man now and of course suffered a brain injury last year.
OK thanks for explaining so I can safely reduce those settings way down 0.15mm (0.006") inlet and 0.2mm (0.008") exhaust then?
You realise I will have to re-do all those b****y shims again!
Russ Cooper
Dursley
UK
#13 Post by soe8m »
Yes and the engine becomes less noisy.
#14 Post by tony g »
Yes and then run out of thicker ones at No 8 :)
You realise I will have to re-do all those b****y shims again![/quote]
trackerjack
#15 Post by trackerjack »
I feel your pain as I have just done an engine for someone and ALL the shims had to be bought as non that I had were suitable which is amazing considering I had a pot full of the pesky things.
I found Robsport were very helpful with what I needed.
