Merry Christmas, Happy New Year and all that
Does anyone know if one of these would fit a Sprint?
(It fits the sixes, Spitfire and Stag so I'm assuming so)
http://www.rareelectrical.com/p-13400-n ... -stag.aspx
Cheers,
Garth
You can reduce the load by altering the plumbing to use one pump and a remote thermostat, thereby getting rid of the booster pump and controller.speedracer wrote:Running electric water pump + controller + electric booster pump + thermo fan + multi spark...
Hi Garth, With an overall outside diameter on the thick brown wire of about 4mm, the copper conductor is probably going to be 56 x 0.3mm^2 stranded cable or 12 A.W.G. which is rated at 41A continuous. I'll see if I can measure one up when it stops raining. This is typically 5.2mOhms /meter , or will drop 500mV at 100A.speedracer wrote:Lots of good stuff in those replies - thanks all!
The brown lead from the alternator to the terminal block is approx. 4mm in diameter and looks very original, so potentially i'm not even getting the use of my 55amps? Might try some new fatter copper.
I assume that putting a multimeter across the terminal block and body when the engine is running will give me an indication of how accurate the in-car voltmeter is?
Cheers,
