Tail/rear light seals
Is there a source or a good alternative that anyone has used for the inner and outer seals?
Re: Tail/rear light seals
... or a source of suitable material from which to make replacements using the compressed and crumbly originals as templates?Maidstonerob wrote:Is there a source or a good alternative that anyone has used for the inner and outer seals?
Crumbly being the understatement lol! I dont think i have the ability or patience to sift it into the correct shape. I wonder what would be a suitable material to try to cut out our own replacements neoprene or silicone rubber.Pippin wrote:... or a source of suitable material from which to make replacements using the compressed and crumbly originals as templates?Maidstonerob wrote:Is there a source or a good alternative that anyone has used for the inner and outer seals?
Surprised to see Rimmers stock them both inner and outer seals
Have ordered a pair of each, I hope they are up to it.
I bought mine from Rimmers a few years ago and I was pleased with them, nicely cut and the foam seems to be like the original.
malcolm
malcolm
Having had a look at both TR6 and MGTF light seals they seem to be neoprene foam which is readily available on a well known auction website! Try a search for 'neoprene foam sheet'. Closed cell neoprene is waterproof. Not sure what thickness is needed, although uncompressed TR6 seals are 11mm thick (just measured one).
1980 Dolomite 1850HL Auto
1977 Dolomite 1500
1977 Dolomite 1500
