Alternative Sprint Distributor Cap
ham204
#1 Post by ham204 »
Is this a good alternative to the Sprint 44D4 distributor cap:
http://www.ebay.co.uk/itm/AMBASSADOR-1- ... 2217108034
On a related subject, isn't it strange that spark plug leads (at least the ones I have seen) do not have a 90 degree exit from the cap to the plugs? That would help to manouvre them over the inlet manifold to the plugs.
1972 Spitfire MK IV
1972 Stag
1980 Sprint
1962 Land Rover Series 2a
1983 Land Rover Series 3
1995 Suzuki Samurai SJ413
Hmm…...
#2 Post by sprint95m »
I don't know whether that one is a good alternative but an Ambassador cap can be used.
You will need the Lucas 45D rotor arm too.
Please beware, there are some really rubbish replica ignition parts around.
Further, you will also need ignition leads because the Ambassador used the simple push on type.
