The first picture is a KA setup that uses smaller 48 mm pistons rather than the Sierra type which use 54 MM pistons. Either have no trouble stopping a Sprint over and over without fade.
Also note that the copper pipes are not recommended as they impair performance as the caliper has to move freely. If you are not competent do not work on your brakes and please ensure all parts work correctly. I show these mods but it is your responsibility to have a safe car.
This picture shows the standard set up that BL fitted which was the same for all Dolomites and Toledo and though the Sprint was more than twice the BHP and 35 MPH faster than a 1300 it merely had a bigger servo which even in 1972 was shamefully poor engineering IMHO.
This shows a modified disc that I have cut the threaded part off to use as a clamp ring.
I make some clamp rings from alloy that are much better and I will add a picture soon.
This is a Golf MK2 GTI 239 mm disc that has been bored to 66.7 and drilled to suit the triumph standard unmodified hub.
Here is the cut original disc being used and bolted to the standard hub using original bolts.
Worth noting here that prior to 1976 all Dolomites and Toledo used 3/8 UNF wheel studs and post 1976 the size was increased to 7/16 UNF. I would suggest using the larger type as they have been known to break.
This shows the lower ball joint which now suffers with heat as it is closer to the hot disc as the vented are wider so retain the sheet metal guard which protects it. The bolts must not protrude here so make sure they don't. I have shaved a little off the upright shown as on full suspension bounce or badly set wheel bearings the disc will scrape them. This is very important.
This shows an upright that if you notice has had one of the ears cut off to allow my brackets that I have laser burnt to a drawing kindly done by Mad Mart to my design they are made from EN8 steel and ground flat then I jig drill them to suit.
Finally these are the pads that fit the calipers and are freely available in standard to race and priced accordingly by Motor Factors.
