Refitting Mechanical Fuel Pump
As the title says, I'm removing the electronic fuel pump fitted by the PO and refitting a mechanical pump. The Parts catalogue says that the part number for the gasket to the pump is UKC8523 which is about 1/2 inch thick. Rimmers says this part is for the 1300 and 1500, the gasket for the Sprint being the thin one.
So who's right? I have to say that fitting the pump with the thin gasket proved to be very difficult
1972 Spitfire MK IV
1972 Stag
1980 Sprint
1962 Land Rover Series 2a
1983 Land Rover Series 3
1995 Suzuki Samurai SJ413
1972 Stag
1980 Sprint
- Flyfisherman
Re: Refitting Mechanical Fuel Pump
ham204 wrote:As the title says, I'm removing the electronic fuel pump fitted by the PO and refitting a mechanical pump. The Parts catalogue says that the part number for the gasket to the pump is UKC8523 which is about 1/2 inch thick. Rimmers says this part is for the 1300 and 1500, the gasket for the Sprint being the thin one.
All depends on which fuel pump you have as there are two varients.
One pump has a longer crank arm than the other pump - if you purchase the pump with the long crank arm you require a spacer (UKC8523) + two paper gaskets short crank arm no spacer but you will require one paper gasket -see attached for pictures.
http://www.rimmerbros.co.uk/Item--i-GRID008455
This is what I bought over ebay.Its a QH but doesn't look like either of the two Rimmer 'Sprint' fuel pumps!
- FUEL PUMP.jpg (30.76 KiB) Viewed 4974 times
1972 Spitfire MK IV
1972 Stag
1980 Sprint
1972 Stag
1980 Sprint
Why did the pumps have different length arms? Were they to fit different camshaft drives? I need a new one but am unsure which one to order.
The diagrams on page 1K 10L of the 1981 parts book explain a lot.
Early 1850s and Sprints were fitted with a 312167 fuel pump. This is commonly referred to as the "short arm pump". It was fitted with a single thin gasket.( But note that the workshop manual refers to adjusting the fuel pump pressure downwards if neccessary by fitting extra gaskets. )
Later 1850s and Sprints were fitted with a TKC3419 ( = RKC5051 ) fuel pump together with a 13mm plastice spacer block part number UKC 8523. This is referred to as the " long arm pump ". The spacer block moves the later pump furthur from the mating face on the cylinder block to give the same pump pressure.
They give the change point as "May 1978".
I've taken a sample of each pump and drawn round the operating-lever profile of each pump.
1 Is the early slant 4 pump, which is actually a QFP32 QH version
2 Is a later slant 4 pump, QFP33 QH or 17110029 for a genuine AC pump.
3 Is a later slant 4 pump, with the spacer block fitted.
A genuine A.C fuel pump for the early slant 4 cars has 7990047 stamped on the operating lever.
A genuine A.C fuel pump for the later 1850 / Sprint cars is stamped 7990487.
If swapping from early to late fuel pumps you have to change the fixing bolts as well.
Early (short ) are 149673 x2
Late ones (long) areSH605101 x2
In each case the mating face of the pump is on the LHS of the graph paper.
Try printing this out at various scale factors to get the 50.00mm scale I've drawn in at the top.
Now 1300s and 1500s are different again.
Early 1300/1500s have RKC1624 pumps
There is no mention of what later 1300s have but later 1500s have an RKC5049 pump ,.longer studs TE605041 and this UKC8523 spacer block. The profile of the 1500 pump lever is very different to the slant 4 item.
Slight problem is the spacer block is NLA so its going to be EBay or similar.
And yes I've got caught out with a so-called "genuine Sprint long arm fuel pump ". It is similar but not close enough and has a different number stamped on the operating lever.
HTH,
HTH,
- slant4 fuel pump shrink.jpg (53.72 KiB) Viewed 4938 times
Wow, migwelder, what a lecture! This should be pinned somewhere on this forum
If the spacer block is 13mm wide, then Rimmers have it
1972 Spitfire MK IV
1972 Stag
1980 Sprint
1972 Stag
1980 Sprint
- Flyfisherman
Nice one Tony - I was trying to find an item that you had written about various fuel pumps
viewtopic.php?f=4&t=27865&hilit=sprint+fuel+pump
Paul
Paul
So both the fuel pumps work on a 1500 only you use the spacer block with the long arm?
Don't know why you would replace a electric pump for a mechanical one ( unless it's a concurs car and it's for originality), got rid of the mechanical pump 20yrs or so ago because of all the faffing about with different pumps and different arm sizes, no more cranking for me to fill up the fuel bowls and much more reliable
It has to pass a classic car test in Malta, where it is now based) and a ticking fuel pump won't do my chances any good......mahony wrote:Don't know why you would replace a electric pump for a mechanical one ( unless it's a concurs car and it's for originality), got rid of the mechanical pump 20yrs or so ago because of all the faffing about with different pumps and different arm sizes, no more cranking for me to fill up the fuel bowls and much more reliable
1972 Spitfire MK IV
1972 Stag
1980 Sprint
1972 Stag
1980 Sprint
In that case good luck with the pumpham204 wrote:It has to pass a classic car test in Malta, where it is now based) and a ticking fuel pump won't do my chances any good......mahony wrote:Don't know why you would replace a electric pump for a mechanical one ( unless it's a concurs car and it's for originality), got rid of the mechanical pump 20yrs or so ago because of all the faffing about with different pumps and different arm sizes, no more cranking for me to fill up the fuel bowls and much more reliable
I manged to find a new spacer block, I think it was for a Spitfire. It fits and it seems to be the right thickness for a Sprint.
cleverusername wrote:I manged to find a new spacer block, I think it was for a Spitfire. It fits and it seems to be the right thickness for a Sprint.
How thick is it?
1972 Spitfire MK IV
1972 Stag
1980 Sprint
1972 Stag
1980 Sprint
- Flyfisherman
10mmham204 wrote:cleverusername wrote:I manged to find a new spacer block, I think it was for a Spitfire. It fits and it seems to be the right thickness for a Sprint.
How thick is it?
Paul
- TDC Cheshire Area Organiser
NOW A CLUB MEMBER 2017057
