Can someone please put up a photo of the choke trunnion as it fits into the carb?
I forgot to photograph mine and it then promptly fell out never to be seen again.
Choke cable trunnion
1972 Spitfire MK IV
1972 Stag
1980 Sprint
1962 Land Rover Series 2a
1983 Land Rover Series 3
1995 Suzuki Samurai SJ413
1972 Stag
1980 Sprint
- Flyfisherman
Re: Choke cable trunnion
Hamham204 wrote:Can someone please put up a photo of the choke trunnion as it fits into the carb?
here you are http://www.rimmerbros.co.uk/Item--i-AUE34
Paul
Thanks Paul,
That's it? No washers or anything else?
1972 Spitfire MK IV
1972 Stag
1980 Sprint
1972 Stag
1980 Sprint
- Flyfisherman
No washers or pins etc, the choke cable goes through the hole and is secured in place to prevent it slipping via that small retaining screw, same idea as the screw on the heater fan box under the bonnet and the bonnet catch.ham204 wrote:Thanks Paul,
Paul
I suggest you purchase a section of 15amp electrical chocolate block and use one of the connectors.
I purchased this, originally for the MGB but works perfectly for the HS6 carb
- ggggg resized.jpg (223.33 KiB) Viewed 1303 times
1972 Spitfire MK IV
1972 Stag
1980 Sprint
1972 Stag
1980 Sprint
