poly bushing is it all that???
RON13R
#1 Post by RON13R »
I know this has been done many times before but to be honest Im too lazy to trawl through the threads
so whats your opinion on poly bushing
is it worth doing
wich ones do you recomend
how much do they cost
can you choose the type of ride
easily fitted or does it require a press
cheers peoples
Galileo
Re: poly bushing is it all that???
#2 Post by Galileo »
Superflex from Chris Witor Triumph. :posting:
#3 Post by Jon Tilson »
Depends....
I just do a few on mine...drag strut to front subframe, subframe to body and rack mountings.
Always use the OE rose joint on the lower wishbone to sub frame too.
Flyfisherman
#4 Post by Flyfisherman »
RON13R wrote:I know this has been done many times before but to be honest Im too lazy to trawl through the threads
is it worth doing
cheers peoples
Have look at this thread
viewtopic.php?f=4&t=32349
Mines all done front to back - I bought all my bushes from viamoto and saved myself a lot of money.
https://www.viamoto.co.uk/products.php? ... %26+Toledo
Dont buy the shock top bush they are useless - dont fit the domed washer correctly so I purchased these, 100% better.
http://www.rimmerbros.co.uk/Item--i-517985POLY
Paul
Galileo
#5 Post by Galileo »
Chris Witor is Superflex, not just a reseller, and there are complete kits which are cheaper than the individual components, plus if you're a TDC member there's a discount, think it was 20%.
tinweevil
#6 Post by tinweevil »
I'm with Jon, depends. The ones I do are drag strut to front subframe and rear upper link to axle and I do those because the rubber doesn't last not anything to do with ride when they are fresh. I certainly agree with Jonners on the rose joint. 99.9% of the improvement that comes from poly comes from the rubber they replace being shot.
#7 Post by soe8m »
Galileo wrote:Chris Witor is Superflex.
Well you haven't see me perform yet.
#8 Post by Toledo Man »
I'm with Raf. SuperFlex is the one to go for. They're worth the money. Chris Witor is the official UK disributor so to all intents and purposes he is SuperFlex. I replaced the bushes on my lower suspension arms with SuperFlex ones and they've been fine ever since. Some bushes might need a vice but it is all DIY-able.
#9 Post by sprint95m »
is it worth doing
Yes
RON13R wrote:which ones do you recomend
I have only used Superflex and I am going to do so again.
They are produced with "fast" road in mind.
RON13R wrote:how much do they cost
Please see Chris Witor's website. If you phone him he'll give a discount there and then (since you are a TDC member),
subject to the minimum order requirement being met.
RON13R wrote:can you choose the type of ride
Not with Superflex (although they do have some options, e.g. for T2000 drag struts).
Other makes have options, but I have no experience of these so therefore cannot offer an opinion.
RON13R wrote:easily fitted or does it require a press
For Superflex yes, no press is required.
A large vice and/or threaded bar with sockets and washers will suffice.
All Superflex bushes have proper stainless steel tubes, which simply slide into place
after first fitting the bush.
SprintMWU773V
TDC Staffs Area Organiser
#10 Post by SprintMWU773V »
Some of the Polybush branded ones are available in 'comfort' spec and also some of them are in two halves so are really easy to fit. Polybush are the only other polyurethane bushes I would recommend. They are available from numerous stockists or direct from Polybush themselves.
Some I fitted with a press because I happened to have one, it made it really easy but you could also use a threaded bar as already suggested.
grahamwatson
#11 Post by grahamwatson »
Send me a PM with your email address and I will send you a spreadsheet showing the current prices from Rimmers, ANG, Witors, Wins, Paddocks, Quillers and Polybush.
The spreadsheet also shows what they include in their various kits.
And also read this recent thread viewtopic.php?f=4&t=32349. Despite what others are suggesting there is no additional club discount on Chris Witor's already discounted kits.
Galileo
#12 Post by Galileo »
Slow down a bit, dinner and a movie first.
Galileo
#13 Post by Galileo »
grahamwatson wrote:
RON13R wrote: Despite what others are suggesting there is no additional club discount on Chris Witor's already discounted kits.
This must have changed recently then, as I looked up the invoice and the complete kit that I bought in September 2015, listed as SPF0374FBKD for £183 at the time, came with 10% off.
grahamwatson
#14 Post by grahamwatson »
Galileo wrote:
grahamwatson wrote: Despite what others are suggesting there is no additional club discount on Chris Witor's already discounted kits.
If that was the front bushes kit it is now listed at £149 plus VAT (on Chris Witor's own site, not his Superflex site). That is more or less a 15% discount on the list prices (on the Superflex site) of the individual bushes in the kit.
His rear basic kit is now £94.50 which is also a 15% on the individual bush prices. That has come down from the £100 plus VAT I paid last week. Must have been something I said! I see that Chris has also now put a note on the kit details that no further discounts apply.
I don't really have a problem with any of this but I did get into it thinking (like others, it seems) that I would get a club discount on the kits. Eyes now open!
I have updated my spreadsheet to cover the rear kit price change. PM me with your email address if anybody wants a copy.
grahamwatson
#15 Post by grahamwatson »
Thanks for this link Paul. I have added Viamoto to the spreadsheet. Some interesting prices in there!
